Just put in some 15' inch rims and stearing problems
well a couple of days ago i had some hx rims and they worked fine i can drive and let go of teh stearing whell and drive straight for a while and when i replaces them with buddy club 15's with falken azenis my car would stear to teh left like 2 seconds after i let go of teh stearing wheel even though im on flat, completly flat ground anyone know the reason? or can give me an reasonable explination
If it's a different size rim and tire from your stock ones, you probably need an alignment. Did you double check tire pressures? Are the tread depths even on your front tires? Are the rims possibly bent or warped? All of this will contribute.
or you need to balance your wheels...check your tire pressure...it can be all kinds of things...check the pressure first...if not take it to a shop and get it checked out
iCollectStraws
May 21, 2009 05:06 AM
