2 O2 sensors on b16a1???
Old Mar 13, 2005 | 12:26 PM
sloweh3's Avatar
Default 2 O2 sensors on b16a1???
Ok, here's the deal, on my first gen b16, my stock manifold had 2 o2 sensors on it, 1 wire for each of them. I bought a b18(90-91 integra) header for it, and it only has 1 o2 sensor hole. I plugged up one of the sensors and ran the car. Now I'm throwing a code 2 (o2 sensor).
I was wondering if any of you have this problem, and how would I fix this? The CEL is so damn annoying.
Old Mar 13, 2005 | 12:33 PM
Dragline's Avatar
Default Re: 2 O2 sensors on b16a1??? (1point6DA)
You should be running both of them thats why you have a cel,that ecu needs both to properly supply fuel to all 4 cylinders,with out both,2 of your cylinders will run leaner than the others.
Old Mar 13, 2005 | 02:43 PM
NikoZai's Avatar
Default Re: (SwapShopR)
What this does exactly is use the O2 reading from cylinders 2 & 4 (right #s?) and tell the ECU that 1 & 3 are doing the same.
Old Mar 13, 2005 | 02:45 PM
doublethink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwapShopR &raquo;</TD></TR><TR><TD CLASS="quote">Here is alittle trick. Go to your ECU plugs & jump C8 to C16 (leaving the existing c16 wire intact) Then you can just run the stock o2 sensor as normal.</TD></TR></TABLE>
that may make the code go away, but he should get the ecu chipped to run that single 02 sensor or go obd1...
the ecu needs to see two, and the low collector needs a heated o2 sensor to work properly, the 2 on a b16a are not, since they are so close to the block.
just some things to consider.
Old Mar 13, 2005 | 04:21 PM
sloweh3's Avatar
Wouldn't doing this be the same? Basically, the o2 sensors plug into 2 different plugs on the front of the tranny. Couldn't I splice and soder the wires into one? Wouldn't that be just like jumping the wires at the ecu?
Old Mar 13, 2005 | 04:23 PM
SwapShopR's Avatar
No Sales Forums
Default Re: (1point6DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1point6DA &raquo;</TD></TR><TR><TD CLASS="quote">
Wouldn't doing this be the same? Basically, the o2 sensors plug into 2 different plugs on the front of the tranny. Couldn't I splice and soder the wires into one? Wouldn't that be just like jumping the wires at the ecu?</TD></TR></TABLE>
Yes it will work just fine.
Old Mar 13, 2005 | 05:46 PM
Dragline's Avatar
maybe SwapShop should reads this,you think it works your way
http://www.hondata.com/techo2problem.html
Modified by dragline at 11:45 PM 3/13/2005
Old Mar 13, 2005 | 07:32 PM
sloweh3's Avatar
Default Re: (dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">maybe SwapShop should reads this,you think it works your way</TD></TR></TABLE>
What do you mean?
Old Mar 13, 2005 | 08:05 PM
Rywire's Avatar
dont solder both into 1, you will not run correct(too rich/lean), do it how honda intended.
Ryan
Old Mar 13, 2005 | 08:26 PM
87sivtec's Avatar
^^Correct!
Just get two O2 sensor bungs welded on to the header where they were on your B16 manifold. Do it properly and your mileage and driveability will be waaaaay better than if you jump them.
Old Mar 13, 2005 | 09:39 PM
sloweh3's Avatar
Default Re: (87sivtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87sivtec &raquo;</TD></TR><TR><TD CLASS="quote">^^Correct!
Just get two O2 sensor bungs welded on to the header where they were on your B16 manifold. Do it properly and your mileage and driveability will be waaaaay better than if you jump them. </TD></TR></TABLE>
Would an exhaust shop be able to tap another hole on my header to run another o2 sensor?
Old Mar 13, 2005 | 11:49 PM
Rywire's Avatar
Yes, have them weld in 2 new o2 bungs in stock locations. I believe 1 sensor measures 1&2 and the other does 3&4 (not sure!) . If you start to bog after this , switch the pins c8 and c16 at the ecu... trust me
Ryan
Old Mar 14, 2005 | 04:44 PM
87sivtec's Avatar
Default Re: (droppedcrxsi)
The O2 sensors are paired up for 1-4 and 2-3 actually.
Get them to do it like hasports header here:
racingant
12
Nov 11, 2005 06:41 PM
swtch7
Jul 15, 2005 03:19 PM
SI_Ro
Aug 7, 2004 07:21 PM
quik89
Jul 24, 2004 03:40 PM
Shakes
Apr 28, 2004 08:45 PM
