Most WHP on stock block?
Old Mar 13, 2005 | 11:24 AM
chero112's Avatar
Default Most WHP on stock block?
What's the most WHP you guy's put down on a stock block? I'm hoping to hit 180-190. can It be down with a stock block........ My set up is 00 gsr obd-1 stock block, with head work(crower valve, valvesprings, retainer) 3 angle valve job, CTR cams... and soon to come skunk2 intake manifold....... Did a search nothing really usefull..... Thanx
Old Mar 13, 2005 | 12:55 PM
Hondog's Avatar
Default Re: Most WHP on stock block? (chero112)
dunno on an 1.8. I know a guy local to me that makes around 220whp with a stock 1.8 block, CTR pistons. Ported head, crane stage 2's, fererra valves etc..
And I make over 260whp on a stock K20A block..
Old Mar 13, 2005 | 01:17 PM
chero112's Avatar
Default Re: Most WHP on stock block? (Hondog)
I was reading this Thread and these guy I think put down 190 or sure with a b16 and with a stock block...... I've being trying to find that Thread but had no luck...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondog &raquo;</TD></TR><TR><TD CLASS="quote">dunno on an 1.8. I know a guy local to me that makes around 220whp with a stock 1.8 block, CTR pistons. </TD></TR></TABLE> That's good #, but He changed his piston's to CTR, I was meaning stock block as p72 piston and rods Etc... but thanx tho
Old Mar 13, 2005 | 01:21 PM
Hondog's Avatar
yea going to the CTR pistons gives you just under 12:1 comp thats where the power is made... I'd recomend it, not a huge expense while the head is off..
Old Mar 13, 2005 | 01:44 PM
chero112's Avatar
I Made the mistake of putting the head back in the car as soon I got it back form the machine shop.... You see My goal is 190 no more no less... If I can't do it with a stock p72 block I guess I'm going to have to pull the head off again and do the block.... but If I going to go that route I'm just going to start all over and do the head and the block.....
Old Mar 13, 2005 | 05:37 PM
BACKintheDA's Avatar
omniman's 200 whp b16 stock block
Old Mar 14, 2005 | 01:01 PM
631 Teggy's Avatar
Default Re: Most WHP on stock block? (BACKintheDA)
My friend put Jun3 cams in a stock jdm gsr motor.... With i/h/e and Jun3 cams the car made 193whp...
Old Mar 14, 2005 | 02:51 PM
97L-esVeeTeg's Avatar
Default Re: Most WHP on stock block? (631 Teggy)
got a friend that put down 180hp with a usdm gsr stock block and Jun 3's and vafc
Old Mar 14, 2005 | 03:40 PM
chero112's Avatar
Default Re: Most WHP on stock block? (97L-esVeeTeg)
Don't you have to bump up your compression to run Jun 3's........
thanx been searching and there not to many people hitting 190 with a stock block unless there runing some big cams.... I going to dyno my car trying to get my hand on some skunk2 satge1 for the dyno... thanx guys
Old Mar 14, 2005 | 06:08 PM
Kendall's Avatar
chad put down 190 whp on a stock longblock B18C5 last year, and since then, I've seen three stock shortblock GSR's do it. All three were running with thin headgaskets and some milling, along with aftermarket cams/valvetrain. One was using ITB's, the other two were using Skank2 IM's. The one with ITB's was running a Toda header, one of the others had a DTR, and I can't remember what the third guy had.
Old Mar 14, 2005 | 09:36 PM
strsi's Avatar
Default Re: (Kendall)
I put down 178whp on a stock block usdm b16!
Mods & dyno are all here https://honda-tech.com/zerothread?id=1149781
jaredvabeach
Sep 14, 2009 01:53 PM
dantamparacer
Jul 27, 2009 11:52 PM
KiNG $h!t
49
Jan 7, 2008 04:39 PM
DIPSETRACER
May 25, 2005 09:04 PM
