I need bore size info.any body got a 93 haynes manuel?
i need the id on a stockd15b8 block cylinders, i need piston rings for the b8 pistons and block and i need to know the inside diameter of the cylinders so i can getthe right diameter rings please lemme know either by reply, im , or email.hypnotixcrx@aol.com
Isnt it the same as every other single D-series out there?
75mm
Rather, to be exact:
Standard (New): 74.980-74.990mm (2.9520 - 2.9524 in)
Service limit: 74.970mm (2.9516 in)
75mm
This is Per manual
Engine Block
cylinder bore..........................2.9528 to 2.9535 inch
service limit............................2.9555 inch
cylinder taper limit..................0.002 inch max
Cylinder out-of-round limit.......0.002 inch max
block deck warpage................0.003 inch
service limit...........................0.004 inch max
pistons and rings
piston diameter.........................2.9520 to 2.9524 inch
service limit..............................2.9516 inch minimum
piston to cylinder-wall clearance..0.0004 to 0.0016 inch
service limit...............................0.002 inch max
ring groove clearance
<U>top compression ring</U>
d15z1....................................0.0014 to 0.0024 inch
service limit...............................0.005 inch max
all others...................................0.0012 to 0.0024 inch
<U> Secound compression ring</U>
d15z1........................................0.001 2 to 0.0024 inch
serive limit.................................0.005 inch max
all others...................................0.012 to 0.0022 inch
<U>Ring end gap</U>
Top compression ring..................0.006 to 0.012 inch
service limit...............................0.024 inch max
second compression ring.............0.012 to 0.018 inch
service limit...............................0.028 inch max
oil control ring
d15z1 and d16z6........................0.008 to 0.028 inch
service limit...............................0.031 inch maximum
d15b7 and d15b8.......................0.008 to 0.031 inch
service limit...............................0.035inch maximum
thats all the info i could find in my book with out reading word by word
Engine Block
pistons and rings
<U>Ring end gap</U>
oil control ring
