which way do Rods face???
Old Mar 13, 2005 | 10:30 AM
MugenB16A2's Avatar
Default which way do Rods face???
I'm having my LS rods pressed onto a set of PCT's and just want to make sure that EVERYTHING is assembled facing their respective directions...
I know that the TOPS of the Pistons have an Arrow and they are supposed to be facing or pointing towards the Crank Pulley...
But what about my rods??? One side has the Oil Passage hole on the Rod, and also the number that is stamped on them for Bearing codes.... What side are those supposed to be facing??? Front of Block or Back???
Thanks...
Old Mar 13, 2005 | 10:45 AM
boosted k20's Avatar
Default Re: which way do Rods face??? (MugenB16A2)
the numbers should be facing the front of the block. it shouldnt really matter cuz hopefully the machine shop put in the pistons on the rods correctly. so all u need to do now is follow the arrow on the piston
Old Mar 13, 2005 | 11:03 AM
MugenB16A2's Avatar
Default Re: which way do Rods face??? (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">the numbers should be facing the front of the block. it shouldnt really matter cuz hopefully the machine shop put in the pistons on the rods correctly. so all u need to do now is follow the arrow on the piston</TD></TR></TABLE>
Thanks... I've used this machine shop before on other builds and they were great, I am just trying to Double check and that way I can have a better Momery for next time...
Old Mar 13, 2005 | 01:28 PM
slofu's Avatar
check the big ends of the rods. the bearing tangs should face the exhaust side, or your likely to have oil problems.
Old Mar 27, 2005 | 11:40 PM
MugenB16A2's Avatar
Default Re: which way do Rods face??? (slofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slofu &raquo;</TD></TR><TR><TD CLASS="quote">check the big ends of the rods. the bearing tangs should face the exhaust side, or your likely to have oil problems. </TD></TR></TABLE>
I'm assuming by "Tangs", you mean the Oil hole in the rod....
So, the Numbers and the "Tangs" face the Front (Exhaust side) of the Block....
Old Mar 28, 2005 | 12:07 AM
mtber's Avatar
Your welcome
LudaChris
Feb 28, 2007 06:38 PM
fknfast
Jun 19, 2005 07:12 AM
jdmsijdm
Jul 8, 2004 11:04 PM
ITSTOCK
Apr 2, 2004 04:45 PM
yusoslo
Dec 16, 2003 06:56 PM
