Greddy Oil return line SOHC size *learn the hard way*
Old Mar 13, 2005 | 09:59 AM
Cee_mon's Avatar
Default Greddy Oil return line SOHC size *learn the hard way*
I had a small leak in my oil return line for my greddy kit. We all know that cheap rubber hose that comes with the kit wont last forever. I asked acouple people for size before i started this project so i would have the spare hose here. Well I was told 1/2in INSIDE diameter. Turns out they were wrong and i measured my stock oil return line that came with the greddy kit and the INSIDE diameter is 3/4in.
Cliff notes... Greddy oil return line for SOHC is 3/4in INSIDE diameter.
Old Mar 13, 2005 | 10:06 AM
oxSLEEPERxo's Avatar
Default Re: Greddy Oil return line SOHC size *learn the hard way* (Cee_mon)
if you need a replacement quick, try autozoneor advance autozone for their thick fuel line
Old Mar 13, 2005 | 11:53 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cee_mon &raquo;</TD></TR><TR><TD CLASS="quote">I had a small leak in my oil return line for my greddy kit. We all know that cheap rubber hose that comes with the kit wont last forever. I asked acouple people for size before i started this project so i would have the spare hose here. Well I was told 1/2in INSIDE diameter. Turns out they were wrong and i measured my stock oil return line that came with the greddy kit and the INSIDE diameter is 3/4in.
Cliff notes... Greddy oil return line for SOHC is 3/4in INSIDE diameter.</TD></TR></TABLE>
****, I run a heater hose for my oil return line (much to the dismay of the Checker parts guy ), **** works fine
Old Mar 13, 2005 | 05:00 PM
y7turbo's Avatar
yep i use 3/4" rubber heater hose from napa.. works just fine..
Old Mar 13, 2005 | 08:38 PM
miro_gt's Avatar
Default Re: Greddy Oil return line SOHC size *learn the hard way* (konigturbocivic)
so what's wrong with the hose that comes with the kit ?? .. I used that heat resistant paper that comes as well ... not sure what will happen ... just put it 3 hours ago (when I finished the whole kit)
Old Mar 14, 2005 | 08:01 AM
Cee_mon's Avatar
Default Re: Greddy Oil return line SOHC size *learn the hard way* (miro_gt)
Its just a normal rubber hose. Mine lasted for 2 years without problems. But now has sprung a leak.
Old Mar 14, 2005 | 08:59 AM
turbo sol's Avatar
the rubber hose becomes hard and brittle from the heat, as long as nothing hits or moves it i imagine it would be fine., I am gong with one of the fancy hoses with the metel sleeve.
Old Mar 14, 2005 | 09:52 AM
99lspwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cee_mon &raquo;</TD></TR><TR><TD CLASS="quote">Its just a normal rubber hose. Mine lasted for 2 years without problems. But now has sprung a leak. </TD></TR></TABLE>
Actually its not normal hose...Normal hose would be like heater hose which will wear through much more quickly than the hose that comes with the kit..
Old Mar 14, 2005 | 10:30 AM
Cee_mon's Avatar
Default Re: Greddy Oil return line SOHC size *learn the hard way* (99lspwr)
Ok ...I guess my used kit came with a normal hose then.
Another question, should i get some heat foil for the hose?
Old Mar 14, 2005 | 04:38 PM
sporkcrx's Avatar
Heater hose will get mushy after a while. Use a hydraulic type of rubber hose meant for oil and high temp.
Old Mar 14, 2005 | 08:58 PM
miro_gt's Avatar
I did put some heat foil around the hose ... the foil came with the kit
Old Mar 14, 2005 | 09:15 PM
CRXDrew's Avatar
heater hose... you guys are gonna end up on the side of the highway fucked if you don't watch out.
Atleast used NAPA heavy duty red hose.
Old Mar 15, 2005 | 05:27 AM
Flashmn's Avatar
Default Re: (CRXDrew)
aslong as the heater hose is compatible with gasoline and oil it should be fine. Its not really the heat that makes hoses brittle, its the petroleum chemicals in the oil/gasoline that eat the rubber.
xander1100
Apr 28, 2009 08:18 PM
StolenTeg
Apr 15, 2005 09:38 AM
Pikachu
Feb 9, 2004 08:02 PM
Aeka GSR
Apr 25, 2003 09:57 PM
Pengo
Aug 1, 2002 04:35 PM
