PLEASE HELP. EK rear suspention.
Old Mar 13, 2005 | 07:49 AM
ekdriven's Avatar
Default PLEASE HELP. EK rear suspention.
<U>FIGURED THIS OUT SCROOL DOWN FOR NEXT QUESTION</U>
How do i got about taking out the shocks with the spring. do i have to remove the bolt circled in this picture, and then that will drop? or do i have to do something else?
Modified by domgsr at 12:26 PM 3/13/2005
Old Mar 13, 2005 | 07:55 AM
ekdriven's Avatar
bump. the bolt is on there extremely hard i dont want to break is.
Old Mar 13, 2005 | 07:58 AM
EVIL Hx Coupe's Avatar
Default Re: (domgsr)
not that one...
You have to get 2 bolts that are on the chasis, if you stand in front of the wheel and look straight in past it, you'll see 2 bolts, (12mm) take them off and then you should be able to move that whole thing up and down so the shock comes out.
EDIT: 12mm
Modified by EVIL Hx Coupe at 12:11 PM 3/13/2005
Old Mar 13, 2005 | 07:59 AM
pb16b's Avatar
from the bolt you're looking at, follow to the upper camber control arm. remove the two bolts that hold that arm to the body. those are normally not seized like the other bolts with bushings so that'll be your best bet. after those two bolts are removed, the strut will drop.
Old Mar 13, 2005 | 08:02 AM
civictildeath's Avatar
ya they fail to mention this problem in the books. you need spring compressors ($10-20) or you can do it the cheap but more dangerous way ($ depends on injuries and damage). take a jack and jack up the fork of the shock . when high enough to clear LCA (LCA can be pushed down some with bar) pull jack to side just enough to get shock out and let down while standing as far away as possible. again this method is unsafe.
Old Mar 13, 2005 | 08:03 AM
ekdriven's Avatar
i already did the front i have a spring compressor i just dont wanna snap any blots.. and where the control arm is conencted to the body one side of the bot is extreley hard to get to
Old Mar 13, 2005 | 08:05 AM
Default Re: (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">ya they fail to mention this problem in the books. you need spring compressors ($10-20) or you can do it the cheap but more dangerous way ($ depends on injuries and damage). take a jack and jack up the fork of the shock . when high enough to clear LCA (LCA can be pushed down some with bar) pull jack to side just enough to get shock out and let down while standing as far away as possible. again this method is unsafe.</TD></TR></TABLE>
That's not really nessesary... I've done quite a bit of suspension work, and the only reason you would need a spring compressor would be to take the spring out and reuse that shock...
You dont need one to get the fullshock/spring out from the car.
Old Mar 13, 2005 | 08:09 AM
eK9aT10pSi's Avatar
Default Re: (EVIL Hx Coupe)
easiest ive done it many times is to take off the upper arm [2 12mm bolts] and step on the drum and have a friend take out the assembly.
Old Mar 13, 2005 | 08:11 AM
Default Re: (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi &raquo;</TD></TR><TR><TD CLASS="quote">easiest ive done it many times is to take off the upper arm [2 12mm bolts] and step on the drum and have a friend take out the assembly. </TD></TR></TABLE>
There goes the term I needed... Upper arm!!!, I always do it that way.
Old Mar 13, 2005 | 08:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL Hx Coupe &raquo;</TD></TR><TR><TD CLASS="quote">the only reason you would need a spring compressor would be to take the spring out and reuse that shock.</TD></TR></TABLE>
well i dont know what he plans on doing but if he is just trying to change suspension then why play with all these bolts and risk breaking them when he can jsut use the srping somressors and remove one bolt??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by domgsr &raquo;</TD></TR><TR><TD CLASS="quote">i already did the front i have a spring compressor i just dont wanna snap any blots.</TD></TR></TABLE>
then i suggest using the compressors and not removing anymore bolts to remove the shock assembly
Old Mar 13, 2005 | 08:25 AM
ekdriven's Avatar
alright so your saying remove the top control arm wich is this one? now remove option 1 or option 2?
Old Mar 13, 2005 | 08:26 AM
Number 1
Old Mar 13, 2005 | 08:27 AM
ekdriven's Avatar
im putting coil over sleeves onto the shock so i have to take it out.
Old Mar 13, 2005 | 08:34 AM
ekdriven's Avatar
these bolts do not wanna come off. ahhh!!!
Old Mar 13, 2005 | 08:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by domgsr &raquo;</TD></TR><TR><TD CLASS="quote">these bolts do not wanna come off. ahhh!!!</TD></TR></TABLE>
They're a little tough (been there several years) but they'll come out with a little patience and strength.
Old Mar 13, 2005 | 08:58 AM
ekdriven's Avatar
any suggestions to get the bolts off ive tried everythign i can possible do.
Old Mar 13, 2005 | 10:03 AM
Ls_V_TurboSi's Avatar
I didnt read up on all the replies but the bolts you're taking out I NEVER take out.. The bolt thats circled in the first pic thats circled you dont need to touch the one right next to it looks like you already removed it then at the other end of the LCA remove that 14mm bolt, then the 2 14mm nuts on the top of the strut and thats it.. Just go back to the outside of the car and pull the lca down and the suspension will come out...
Old Mar 13, 2005 | 10:18 AM
ekdriven's Avatar
the thing is that theres a cup on the side where the nut is on the end of the LCA that connects to the body i cant get any tool in there to hold it even if it did budge...
Old Mar 13, 2005 | 10:47 AM
B18ek's Avatar
Default Re: PLEASE HELP. EK rear suspention. (domgsr)
Air tools You gotta tighten then loosen, tighten then loosen, tighten then loosen! Trust me this will work for frozen bolts. Also I remove the lower control arm bolt thats on the subframe not all those other bolts
Grade50
Suspension & Brakes
Jul 5, 2013 06:21 AM
bimmeris
Jun 16, 2008 12:42 PM
Del Sol Man
72
Jun 21, 2006 08:13 AM
ZipTieGUy
Feb 27, 2006 06:08 PM
Ragezero76
18
Sep 22, 2002 04:23 AM
