GUTTED DEL SOL?
Old Mar 12, 2005 | 09:26 PM
b18c5 EG's Avatar
Default GUTTED DEL SOL?
i was just wondering if anybody has ever had a gutted del sol? i always here about crx and hatchbacks being gutted but how about a del sol? any pic or what kind of weight did you get down to? also what did you take out?
Old Mar 12, 2005 | 11:03 PM
Kyles ej1's Avatar
Default Re: GUTTED DEL SOL? (94_Del Sol)
hmm ive never seen one now to think about it but im sure u gut the same things as any other car. the panels and carpet
Old Mar 12, 2005 | 11:10 PM
Ls_V_TurboSi's Avatar
Default Re: GUTTED DEL SOL? (93ejay1)
never really heard of it either.. Del sols are probably the least comon cars in the honda world
Old Mar 12, 2005 | 11:11 PM
VTiVTo8000rpm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote"> the panels and carpet</TD></TR></TABLE>
....trunk (no spare/jack), ps/ac, headliner, back seats, sound deadner (a bitch to scrape off)...that should just about do it not sure on how much weight that takes off but it's a decent amount to where you'll notice some accel gain
edit: wait del slo's dont have back seats right ? me+no sleep=
Old Mar 12, 2005 | 11:20 PM
SAMIboarder's Avatar
I just took out everything behind the center consol. that gives alot of extra room in the cabin too. alot of carpet out of that huge trunk, and the tire/jack. I've seen the center console out of one, but you need some kinda rubber boot to help seal the hole up. a/c and ps like was said. maybe the targa rack in the back, but it don't weigh much. maybe the elec. window motor for the rear glass...not sure about that one.
Old Mar 12, 2005 | 11:23 PM
Kyles ej1's Avatar
Default Re: GUTTED DEL SOL? (VTiVTo8000rpm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTiVTo8000rpm &raquo;</TD></TR><TR><TD CLASS="quote">
edit: wait del slo's dont have back seats right ? me+no sleep=</TD></TR></TABLE>
your lucky i saw this before i clikc reply i was just get ready to flame u
Old Mar 12, 2005 | 11:34 PM
your lucky i saw this before i clikc reply i was just get ready to flame u </TD></TR></TABLE>
I almost had to bust out the suit ....I'am getting seasoned
Old Mar 13, 2005 | 06:34 AM
DC-4-Drew's Avatar
I have read where people will cut out he 2 walls behind the seat. The rear window is sandwiched between the metal walls. You have to go back and well some cross bracing in. This is supposed to reduce alot of weight. Not sure how practical it is though.....I am not sure it would be worth it to me though....I guess it depends on what you are looking for.......
Old Mar 13, 2005 | 10:16 AM
b18c5 EG's Avatar
Default Re: GUTTED DEL SOL? (b16a3delsol)
yeah those walls behind the seats are freaking heavy..but your right i dont know if it would be worth it either because personally i like how the back window can go up and down..
Old Mar 13, 2005 | 02:06 PM
dohcVTECeg2's Avatar
you can remove all the panels behind the seats. remove the carpet. and in the trunk remove your spare and all the carpet back there also. you could also remove your power steering and ac if you have it. oh yeah and cruise if u have it also.
Old Mar 14, 2005 | 09:17 PM
b18c5 EG's Avatar
ive been doing some research and i found on darksol.com this info and its great! if anybody has pics of their Gutted sol then post them up!
Almost empty gas tank (2 gallons left) VD -75
Remove cat-back exhaust system R -47
Removed factory A/C, lines, pump, wiring R -43
Remove jack / tools / cover R -22
Remove spare tire R -20
Rear wheels/skinnies (over stock 195-60-14) D -40
Remove passenger seat (over leather stocker) R -33
Front wheels/slicks (over stock 195-60-14) D -32
Remove HVAC system (fan / redirector / console / wiring) R -26
delSol S manual steering rack (over stock power unit) U -22
Remove door motors / lift mechanism R -22
Trim underside of trunk (support web) T -20
Remove radio / speakers / wiring R -17
Carbon fiber hood (over stock hood) U -16
Lexan door windows (over stock glass) U -16
Remove front swaybar (drag only) RD -16
Remove rear bumper reinforcement R -15
Remove windshield wipers / pump / container / lines R -15
JDM ITR 4-1 header (over stocker with heat shield cover) U -14
Lightweight race seat (over leather stockers) U -14
Remove interior carpet / soundproofing (dry ice) R -14
Remove of trunk roof holder / supports R -13
Remove SRS airbags R -13
Remove behind-seat storage compartment R -12
Remove door metal pieces R -12
Remove front bumper reinforcement R -12
Remove rear swaybar (drag only) RD -12
Remove rear window motor/lifter R -12
Remove door mirrors / hardware R -10
Trimmed custom dash / new control console T -10
JUN super lightweight flywheel (over stock) U -9
Remove front window visors / hardware R -9
Trim rear bumper cover T -9
Custom ram-air intake system (over stock system) U -8
Odyssey 680 battery (over stock) U -8
Remove cruise control R -8
Lexan rear window (over stock glass) U -7
Aluminum a/c front engine mount (over stock piece) U -6
Remove under engine cover / trim R -6
Remove aux lights / brackets / wiring R -5
Remove trunk lining / trunk lamp R -5
Unorthodox racing Ultra-R crank pulley (over stock) U -5
Bronze Tint Ameripol polycarbonate roof (over stock metal) U -4
Front bumper cover trimming (96-97 no aux light) T -4
Remove steering wheel knee bolster / plastic cover R -4
Remove plastic under door side trim pieces R -4
Remove VTEC "performance" bar R -4
Trim / reskin door panels (no controls / speaker grills) T -4
Momo Tornado carbon steering wheel (over stock unit) U -3
Remove exhaust heat shields R -3
Remove antenna / wiring R -2
Z.Speed stainless steel brake lines U -2
Energy Suspension bushing master kit U -1
Remove catalytic heat shields R -1
Z.Speed cross-drilled / slotted rotors (over stock) U -1
Z.Speed lightweight lug nuts U -1
Z.Speed short shifter (over stock)
Old Mar 19, 2005 | 12:30 PM
Default Re: (94_Del Sol)
somebodys been doing there book work
Old Oct 9, 2012 | 06:43 AM
mandeecandeex3's Avatar
i see that this post is super old BUT... i wanna show off my gutted del sol (si)
took out everything but the dash and door panels. even the trunk.
weighed at 2200.
Old Oct 9, 2012 | 07:14 AM
StreetsideStig's Avatar
Seems like there's not much to gut.
nighthawkgsr
11
Jan 9, 2006 05:03 PM
GregDelSolSI
13
May 14, 2004 01:25 PM
jdmwidebody094
Nov 11, 2003 12:46 PM
SiKDeLSoL
10
Feb 7, 2003 02:37 PM
