how much did your turbo setup cost you
Old Mar 12, 2005 | 07:21 PM
FormulaGSR's Avatar
Default how much did your turbo setup cost you
I'm curious how much people have spent on boost so i figured i would just ask. We all know roughly how much a turbo kit cost, but thats not what i wanna know. What i want to know is how much you've spent on your entire setup. Everything included. Fuel system, clutch, gauges, fuel management, engine work ect. Also what your setup consists of and how much power your putting down. I think this would be helpful for people considering boosting so they can get an idea of a total investment for a boosted application.
Thanks
Old Mar 12, 2005 | 08:04 PM
Dunc's Avatar
BCICAN
Default Re: how much did your turbo setup cost you (FormulaGSR)
351.18whp right now.....just need sleeves and a block girdle before the big power. So far....I think its roughly 16,700+ just in the engine.
Modified by Dunc at 9:01 AM 3/13/2005
Old Mar 12, 2005 | 08:06 PM
Syke Fu's Avatar
Don't have a turbo car... YET! Urr.. ummm... Yeah a friend of mine spent about $11,000+ just on the motor. It all depends on how deep your pockets are. Or rather how big your credit limit is.
Modified by Syke Fu at 6:44 PM 3/13/2005
Old Mar 12, 2005 | 08:10 PM
icon_race_eg's Avatar
im just startin to build a turbo setup and i gots 2500 to spend right now but i plan on spendinga t least 10 grand on it. credit rules
Old Mar 12, 2005 | 09:11 PM
dan_w_82's Avatar
Default Re: how much did your turbo setup cost you (mac13_34)
Damn I wish I was a big baller like you guys....
I just finished my turbo setup and spent $1800 with engine management. and add $350 for the ACT clutch and flywheel that I got 2 years ago if you want.
93 civic CX
B18b swap Stock internals
BMC Log Manifold
Turbonetics T3/T4 50 trim .48 A/R
Tial 38mm Wastegate
Turbo XS RFL BOV (ricer)
Johnny racer IC
Zeitronix wideband with display
Uberdata (FREEBIE)
uhhhh other odd and end piping etc.
I planned on spending $1400 but went over ohh well I love what I got and I'm still tuning. (Just got it done 2 days ago.)
Old Mar 12, 2005 | 10:14 PM
torr's Avatar
Default Re: how much did your turbo setup cost you (dan_w_82)
about 9g's
Old Mar 12, 2005 | 10:20 PM
dan_w_82's Avatar
Default Re: how much did your turbo setup cost you (torr)
Sorry I just read about <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FormulaGSR &raquo;</TD></TR><TR><TD CLASS="quote"> We all know roughly how much a turbo kit cost, but thats not what i wanna know. </TD></TR></TABLE> just count me out lol
Old Mar 12, 2005 | 11:01 PM
15psi of fun's Avatar
i lost count at million
Old Mar 12, 2005 | 11:17 PM
SHystrdyGSRtdy's Avatar
Default Re: how much did your turbo setup cost you (15psi of fun)
not done yet.. but probably around 3g's
Old Mar 13, 2005 | 12:11 AM
JayFI's Avatar
Bad deja vu or wasn't a thread like this was posted a week or 2 ago?
Old Mar 13, 2005 | 04:19 AM
Boostage's Avatar
Default Re: how much did your turbo setup cost you (Jed Atreides)
how do u put 22k in JUST the engine. did each piston cost $2500? WTF?
Old Mar 13, 2005 | 04:58 AM
Dunc's Avatar
BCICAN
Default Re: how much did your turbo setup cost you (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">how do u put 22k in JUST the engine. did each piston cost $2500? WTF?</TD></TR></TABLE>
My bad man....I opened the excel file but forgot it was for "just the engine" Last time it was 22,000 for everything, but now its up to about 25,000. As for the engine.....it roughly has 16,700+ into it. Sorry for the mistake (I fixed the previous post for ya too).
FormulaGSR: if you want a semi/pretty complete parts list, just click the cardomain. com link in my signature.
Old Mar 13, 2005 | 08:37 AM
oxSLEEPERxo's Avatar
Default Re: how much did your turbo setup cost you (Dunc)
it can get pricy, boost is addicting for some people
Old Mar 13, 2005 | 01:05 PM
Boostage's Avatar
I still cant see 16k in just the engine, a Fully built shotblock(sleeves,rods and pistons, blueprinted and balanced) is about $3000 depending on rods and pistons used, then for the head, even if you got a 5 angle valve job, port and polish, cam gears,springs, retainers,valves and turbo cams I cant see that engine costing more than $5k. or did u mean, all that plus turbo,injectors clutch axles etc etc
Old Mar 13, 2005 | 01:17 PM
platinum00's Avatar
if you look at his parts list on his cardomain page. it does not even come close to 16k.
either this dude is full of ****, or retarded..
Old Mar 13, 2005 | 03:35 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">I still cant see 16k in just the engine, a Fully built shotblock(sleeves,rods and pistons, blueprinted and balanced) is about $3000 depending on rods and pistons used, then for the head, even if you got a 5 angle valve job, port and polish, cam gears,springs, retainers,valves and turbo cams I cant see that engine costing more than $5k. or did u mean, all that plus turbo,injectors clutch axles etc etc</TD></TR></TABLE>
Thats <U>everything</U> so far: cams, new (built) head, rods/pistons, injectors, hondata (the engine needs to be able to run), and I also included labor, blah blah blah. A pile of parts are useless unless there is labor to put them on
It'd be just as easy to figure out how much just in "mechanical" parts I have spent since it's all in an Excel file....If you exclude injectors, manifolds, throttle bodies, turbos, then I guess you could say that all I have spent is about 3,100 just on the head and the block (for parts).
Old Mar 13, 2005 | 04:36 PM
NVturbo's Avatar
O.G. triple O.G.
Whenever I have the time to go through my receipts...I will let you know..LOL Taking a wild guess...hhhhhmmmm...more than $8k including miscellaneous parts/materials. As in horsepower, my old setup made 331hp~291tq. By the end of the month, I should be getting better results since its re-dynoing time!!!
Old Mar 13, 2005 | 04:47 PM
y7turbo's Avatar
Default Re: how much did your turbo setup cost you (NVturbo)
i have about 1400 in my kit on my y7
t3 60trim
johnnyracecar 5" intercooler
2.25 mandrel bent charge pipes.
SAFC
2g dsm 450 injectors
bmc log manifold
1g dsm blow off valve
2.5" downpipe
and a lot of other little stuff that adds up in cost.
it runs great at 11psi .. im gonna do a 5 speed swap soon and do the obd1 conversion so i can run uberdata.. so thats another 1000 for the tranny swap parts..
taylorbishops2k
Dec 24, 2012 03:48 PM
akdrag
Jul 6, 2009 07:27 PM
jxhxb
Sep 30, 2007 03:59 PM
Bense
Apr 7, 2006 05:24 AM
mattduskater
18
Oct 9, 2003 04:09 PM
