loose tie rod..alignment question
Old Mar 12, 2005 | 07:18 PM
brookliner7's Avatar
Default loose tie rod..alignment question
I've been having vibration in the steering wheel and through the car when I acclerate up hills...independent of vehicle speed. just dependent on engine rpm speed.
The car does not pull left or right.
The vibration is getting worse, like a knocking almost when it's around 3k-5k rpm.
I pulled the driver's side wheel off(the half shaft was replaced a year ago) and the alxe seemed fine.
But, the tie rod had about 1/8 of an inch of play in it. should there be play in it? my passenger side was firm, NO play.
could this be the problem with the vibration?
I haven't had the car aligned in years, and it's prett dumped with a camber kit.
any help would be appreciated!
Old Mar 12, 2005 | 07:33 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: loose tie rod..alignment question (brookliner7)
yeah, it won't effect your static toe just sitting there, but while you drive and the suspension is taking its loads, your toe will deffinaelty vary quite a bit AND cause a shaking- allowing the wheel to toe in and out....
New outer tie rods and an allignment will tighten up your steering feel....your vibrations could very well be coming from somewhere else....inner tie rods, wheel bearings, axles, int shaft bearing, etc.
Old Mar 12, 2005 | 07:35 PM
1slowhatchie's Avatar
mine did the same thing and i just tighten it back up just the otherday and i didnt have any more problems with it but the best thing to do is to get it aligned .
Old Mar 13, 2005 | 08:05 AM
ok, quick update....
with the car sitting on the ground, i can pull on the drivers side wheel with my hands (like left to right) and in moves just a little, not much. and the passenger side doesn't move.
inner tie rod or outer? The joint on the outer looks fine....
Old Mar 13, 2005 | 08:22 AM
ironcheftony's Avatar
check ur brake rotors ?
Default Re: (brookliner7)
it made a knocking sound when I turned...not all the time. i'm pretty sure the tie rod is bad, even though the joint looks ok without removing it.
anyone pay a shop to replace em? I know the part is cheap. it looks pretty easy in my haynes manual, i'll prolly just do it myself.
Old Mar 15, 2005 | 04:19 PM
thunking is getting worse...rotors are fine. where's all the honda-tech guru's?
steering wheel doesn't seem to have any place in it which would point to a tie rod.
over bumps it doesn't do the constant thunk-thunk -thunk thunk, just when there is torque. let off the gas, and it goes away. i can coast at any speed, and it will NOT do it. makes me think it's not the tie rod.
Old Mar 17, 2005 | 06:59 AM
DRIVE AXLE!??!?!?!?!?!
Honda92Prelude
Apr 2, 2013 08:59 AM
Dontoh
Aug 28, 2011 05:44 PM
Corksil
Oct 14, 2009 05:37 PM
y7turbo
Suspension & Brakes
Jan 22, 2009 08:45 PM
Backmarker
17
Sep 17, 2002 05:32 AM
