best cam for 85mm ls 13:1 compression gsr head?
when it comes to cams, everyone has their preference. i suggest you look around in past posts. you'll find lots of info.
i suggest toda spec A. it's my favorite cam. but many will say go with jun3, rocket, etc etc.
it's up to you. there's plenty of threads out where this has been covered.
/thread
/thread
You could probably get away with M24x's on that motor, but 13:1 is the minimum compression we recommend. Do you have your heart set on that compression? What will the motor be used for?
I've got a similar setup 85mm B20 with Gsr head 13.1 c/r ... I'm going to be using ROCKET M22 Cams
that's what I would suggeest then you dont have to spend $900 on just cams... you get springs, ret. cams, and spark plugs for $900
let me know if you're interested
that's what I would suggeest then you dont have to spend $900 on just cams... you get springs, ret. cams, and spark plugs for $900 let me know if you're interested
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer »</TD></TR><TR><TD CLASS="quote">And an ECU chip
oh yes... I forgot about that... lol
and from the sounds of it kendall I don't think he has any head work done... sounds liek he might be slapping it together... but I don't know
</TD></TR></TABLE>oh yes... I forgot about that... lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepey »</TD></TR><TR><TD CLASS="quote">thos m24x's look really nice. Im acually thinking about gettin those and sellin my cams. What are the specs of the m24x on the primary lobes?</TD></TR></TABLE>
Same as the M22x
225 duration @ 0.050 and 10.8mm lift
Same as the M22x
unknown0001
Apr 24, 2006 08:00 AM
krystianitr
Sep 22, 2005 09:51 AM
