E-bay CTR pistons...any experience?
I have been looking at these pistons for quite some time...anyone know of any problems with them. They come with wrist pins/rings brand new. Perty cheap. Thanks
No that's just the pic they have, They say they are the ExACT specs as CTR pistons from japan *shrugs*
You can order them 81.5mm bore-81.75mm bore
they have what u seek here http://www.hmotorsonline.com/shop/
NIPPON RACING PERFORMANCE CIVIC TYPE R B16B PISTONS EXCLUSIVE OVERSIZE!!!!!!
NIPPON RACING PERFORMANCE B16B PISTONS
EXCLUSIVE OVERSIZE CTR PISTONS, NOT AVAILABLE FROM ANYWHERE ELSE!!!
PISTON SKIRTS ARE FULLY CERAMIC COATED FOR HEAT PROTECTION
FACTORY PISTONS HAVE COATING OVER 20 PERCENT OF THE SKIRTS
DOMED TO MATCH HONDA'S B16B PISTONS
COMPRESSION WILL VARY FROM 11:1 TO 13:1 DEPENDING ON APPLICATION
WILL FIT MOST B-SERIES BLOCKS
SUPERIOR PERFORMANCE TO HONDA OEM UNITS AND A FRACTION OF THE PRICE
DUE TO RECENT ADVANCEMENTS IN METALURGY THESE UNITS ARE 40 PERCENT STRONGER THAN FACTORY PISTONS
PISTON KIT COMES WITH NPR RINGS AND WRIST PINS.
NPR PRODUCES ONE OF THE FINEST RINGS ON THE MARKET TODAY
UNITS HAVE BEEN TESTED TO OVER 300 HP AND HAVE HELD UP STRONG WITH PROPER FUEL AND TUNING
WOULD MAKE A GREAT UNIT FOR YOUR ALL MOTOR OR NOS CIVIC.
WRIST PIN CENTER TO DOME TOP HAS BEEN MATCHED TO WITHIN .001
DOME CC DISPLACEMENT HAS BEEN MATCHED TO .005 CC
THIS TRANSLATES TO A VERY BALNCED COMPRESSION FROM CYLINDER TO CYLINDER
THESE PISTONS ARE EITHER 81.5MM OR 81.75MM BORE , IF YOU WOULD LIKE STD CHECK MY OTHER AUCTIONS!!!
PLEASE SPECIFY WHAT SIZE PISTONS YOU WOULD LIKE WITH WHATEVER PAYMENT METHOD YOU CHOOSE TO USE, IF NOT THEN YOU WILL BE SHIPPED STANDARD SIZE!!!! FOR EXAMPLE, IN THE "NOTE" SECTION OF PAYPAL WHEN YOU MAKE THE PAYMENT , OR IN A LETTER IF YOU SEND A MONEY ORDER, DO NOT ASSUME THAT JUST BECAUSE YOU SENT ME AN EMAIL YOU WILL GET THE SIZE YOU WANT, MAKE SURE YOU PUT IT WITH THE PAYMENT!!!!!!!!!
hi, just to share my experience with buying ebey pistons, DO NOT BUY, they are cheap and very bad copy of originall product, if you wannt quality buy honda oem pistons, you dont wanna risk your motor for some cheap pistons, well thats just my 5cents, good luck
Everyone thought OBX cams were **** too though untill somebody tried them, I dunno my girl is buying them so maybe I can convince her to spend alil more from hmo, plus the honda mechanic round here goes through hmo....hmmmm decisions decisions
More opinions obliged y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepeg3 »</TD></TR><TR><TD CLASS="quote">these pistons are made by Topline.</TD></TR></TABLE>
The ebay ones I'm looking at?
Dude if you cant afford 169 shipped for pistons maybe you should hold off on this project for a little. Dont forget that putting ctr pistons in a b16 requires some shaving of the piston dome to fit correctly. Not to mention all the hassle of installing them......
well if you wanna build nice reliable, strong runing motor you have to spend $$$$$$$, just think about it you rev it to 8500rpm and something lets go, there goes all your investment, i bought ebey pistons just to see what people actually sell and i compered them to my oem honda ctr pistons there is so many differences in those 2 that i would be just afraid to use it, Rather save some money and buy good stuff or dont buy nothing at all. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mag00n »</TD></TR><TR><TD CLASS="quote">Dude hmotors has OEM CTR pistons for 169.00 SHIPPED. Why not just pick those up?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTiVTo8000rpm »</TD></TR><TR><TD CLASS="quote">$$$ I'm tight budget </TD></TR></TABLE>
if you cant afford $250 for pistons and rings, you should NOT be building a motor....
I know that, I wanted to bore chambers alil anyways. I am saving for the build but dont want to spend all my $$$ on the parts. I'm also buying the OBX s2 cams and some portflow springs/retainers...that's where my $$$ went
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg »</TD></TR><TR><TD CLASS="quote">
if you cant afford $250 for pistons and rings, you should NOT be building a motor....</TD></TR></TABLE>
umm no, I have someone building it for me because all I know how to do is maintenance a car and drive
I think what he means is that your going to run into a lot of small things that add up in $$$ and if 169 is a lot to you maybe you should wait until youve saved up some more.
</TD></TR></TABLE>I think what he means is that your going to run into a lot of small things that add up in $$$ and if 169 is a lot to you maybe you should wait until youve saved up some more.
If these are built to the exact same specs as oem CTR pistons what could go wrong? 169 is alot when it's not my money.
I dunno guess I'll guinnea pig it
i didnt install them because im not gonna risk my motor for some cheap pitons and there is to many visual diffreneces in pistons and im telling you not to waste your money and time, it takes more than just buying ctr pistons, and one more reason why i didnt use it is beacause oem honda product is proven, and it works or i think you should buy it and let as all know how they work, good luck
I just emailed the seller and someone who bought them and see what they say. I asked the seller to provide me with numbers proving they work and if there is any warranty on them. I will keep you guys informed. If it does start to sound sketchy I'll take the negative ebay points, and talk to the mrs. about HMO. Until then
Thanks for all the input ya'll
Sounds good man. Remember, its not worth being a guinea pig. Engine internals are no joke. A lot of work/hours to install pistons. If something goes wrong, not only are you out of whatever breaks, u also have to take all the time of dissembly and reassembly.
I just got my set of nippon racing ctr(81.) copies last week from a guy on here. His name is thevanitygroup and he has a ad for them in the classifieds. I will let everyone know how my build goes after I install them. Here's the list
B17 with ctr pistons, aebs manifold, hondata gasket, ctr pulley, overbore tb, dc header, rsr exhaust, clutch master flywheel, sprung six puck clutch and ebay intake. Im just going to hone the cly walls real fast install new acl rod bearings and slap in the std bore ctr pistons.
** Oh yea the pistons from h motors online dont come with rings
