need help...first time tig welding
Old Mar 12, 2005 | 02:57 PM
ineedhelp's Avatar
Default need help...first time tig welding
well today was my first real day of tig welding. im just messing around with some mild steel, just trying to get the hang of thing. learning how to hold the torch, feed the rod, and using the pedal. doing all this at once is no simple task. i give props to you guys that do this and do it well.
im having some problems with the surrounding of my welds. theres black stuff around it. and theyre small cracks at places.
the machine is asynco 180
-amp set at 80 but im giving it 50% throttle on the pedal.
-argon set at 20 cfh
heres the picture:
the cracks:
some other passes:
Old Mar 12, 2005 | 03:50 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: need help...first time tig welding (ineedhelp)
you didnt prep the metal did you?
Old Mar 12, 2005 | 03:54 PM
project dc2's Avatar
dont worry bout it. its aluminizsed steel. its the coating thats crackling off and flaking. you shouldnt weld that stuff anyways. gives off cynide.
Old Mar 12, 2005 | 04:01 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: need help...first time tig welding (project dc2)
i wonder how they found that out
lol
Old Mar 12, 2005 | 04:14 PM
quickersol's Avatar
Default Re: need help...first time tig welding (wantboost)
really? cyanide? i should probley be more carefull welding that stuff!
Old Mar 12, 2005 | 04:29 PM
ineedhelp's Avatar
Default Re: need help...first time tig welding (quickersol)
i sanded the area down then..wiped it off with acetone.
probably a stupid question but, is old argon gas any good? im using argon that came with an old mig welder...and the mig welder hasnt been touch because the mig wires have rusted. just wondering if it goes bad.
Old Mar 12, 2005 | 09:42 PM
B18C1CYA's Avatar
are you shure it is argon and not a mix gas ???
b16bri
Welding / Fabrication
14
Sep 18, 2011 11:16 AM
booost
Jun 18, 2007 04:23 AM
DXK Eg
Mar 28, 2007 06:03 PM
CooBlueDAB
13
Feb 9, 2005 11:20 AM
cannan
Audio / Security / Video
Jun 8, 2002 07:53 AM
