16x7 or 17x7 or 18x7 - for a daily driven lowered 4 door Teg
Old Mar 12, 2005 | 02:25 PM
schumi's Avatar
Default 16x7 or 17x7 or 18x7 - for a daily driven lowered 4 door Teg
Just trying to decide between 16x7 or 17x7 or 18x7 wheels for a 99 4 door GSR.
It is lowered with Koni yellows + Ground control Coil overs so I will be able to raise or lower the car if needed. I am also planning to roll the lips with my buddies fender rolling machine.
I have a dedicated set of wheels for the track/auto-x. So, current plan is to have this set of wheels for daily use.
1- Which size fits the integra without rubbing issues. Which wheel size looks good?
2- Pros and cons? Like Tires are expensive for 18" wheels? Handling is affected badly by a 17" wheel etc?
There are some Ok deals going on currently. Following are the ones I am considering
1- Brigs 17x7 forged wheel approx $850 shipped
only 14 lbs=> Top preference as I can use it for auto-x also at a later stage
https://honda-tech.com/zerothread?id=969658
2- Velox wheels 16x7 for $500 17x7 for $575 and 18x 7 for $625 shipped
approx 17 lbs each
https://honda-tech.com/zerothread?id=1057746
3- Buddy club 17x7 approx 575 shipped
Not sure abt the weight
https://honda-tech.com/zerothread?id=883611
btw before someone says serach....Idid. Thanks a lot
Old Mar 12, 2005 | 02:27 PM
Rpc07's Avatar
Default Re: 16x7 or 17x7 or 18x7 - for a daily driven lowered 4 door Teg (schumi)
go with the 16x7... 17's on a teg are just too big
Old Mar 12, 2005 | 02:29 PM
.brian.'s Avatar
I would go with the Velox, only because they are 16". I really like the the Brig Mag5, but they only come in 15" and 17". My vote is for the 16" wheels. 17's just look too big for some reason.
Old Mar 12, 2005 | 03:02 PM
.special ed.'s Avatar
get the sixteen inchers. i think anything bigger looks bad on an integra.
Old Mar 12, 2005 | 03:03 PM
Irish Integra's Avatar
Default Re: 16x7 or 17x7 or 18x7 - for a daily driven lowered 4 door Teg (i luv my 97 teg)
Go for 16's, my DA is 50mm down all round on coilovers rollin on 16's and I don't get any scrub noise and they look cool...as was said 17's look too big on a teg
Old Mar 12, 2005 | 03:29 PM
IntegraGSR94's Avatar
Default Re: 16x7 or 17x7 or 18x7 - for a daily driven lowered 4 door Teg (Irish Integra)
My teg is lowered 1.75 inches... and with 17's the ride is heavely sacrificed, so 16's are the way to go
Old Mar 12, 2005 | 03:34 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i luv my 97 teg &raquo;</TD></TR><TR><TD CLASS="quote">I would go with the Velox, only because they are 16". I really like the the Brig Mag5, but they only come in 15" and 17". My vote is for the 16" wheels. 17's just look too big for some reason.</TD></TR></TABLE>
what's wrong with 15s?
Old Mar 12, 2005 | 03:38 PM
schumi's Avatar
Default Re: 16x7 or 17x7 or 18x7 - for a daily driven lowered 4 door Teg (IntegraGSR94)
Thanks for the replys....
Will there by any noticeble difference between 15's and 16's?
As far as "good looks" are considered, does 16's considered better ones than 15's?
With 15's there are so many choices....you get pretty light weight ones also on 15's which can be used for auto-x prurposes?? Tires are also cheap on 15's
thanks again.............
Old Mar 12, 2005 | 03:39 PM
.water's Avatar
Default Re: 16x7 or 17x7 or 18x7 - for a daily driven lowered 4 door Teg (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">
what's wrong with 15s?</TD></TR></TABLE>
he said for daily driven..15's are for hardcore daily drag racer.lol
16's are good enough to show off and go mode..50/50 well depends on brand
Old Mar 12, 2005 | 04:00 PM
uzabatty's Avatar
Default Re: 16x7 or 17x7 or 18x7 - for a daily driven lowered 4 door Teg (Rpc07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rpc07 &raquo;</TD></TR><TR><TD CLASS="quote">go with the 16x7... 17's on a teg are just too big</TD></TR></TABLE>
Old Mar 12, 2005 | 04:08 PM
BANGBANG's Avatar
Old Mar 12, 2005 | 07:33 PM
schumi's Avatar
Default Re: 16x7 or 17x7 or 18x7 - for a daily driven lowered 4 door Teg (BANGBANG)
On 16x7, Velox seems to be the good deal around.....also, new Falkens doesn't come in 15's?
Old Mar 12, 2005 | 07:43 PM
.brian.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">what's wrong with 15s?</TD></TR></TABLE>There is nothing wrong with 15's. It doesn't seem like he wants 15's since it was not listed as one of his choices. I told him to get the Brig's, but they are very hard to find in 16", they are available in 15" and 17".
Old Mar 12, 2005 | 07:53 PM
BlownVR's Avatar
16's will be a nice size for the teg, plus you can have some alright sized tires to make the ride nicer.
Old Mar 12, 2005 | 08:14 PM
Moogen Powah's Avatar
Default Re: 16x7 or 17x7 or 18x7 - for a daily driven lowered 4 door Teg (BoostinVdub)
I'd say go for the 16s in your case. The reason being that 17s+ just look too big on an Integra IMO, and tires are cheaper. As for 16s vs. 15s, it's just up to you. I have 15s currently on my DA, and IMO, it's a good size for the car.
Old Mar 12, 2005 | 10:04 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Default Re: (slow_95se)
Since it's a daily, get the 16's because of tire/rim cost. Although I love the Brigs, and 850 for a forged wheel is highway robbery.
Old Mar 12, 2005 | 10:44 PM
Haleiwa-Brando's Avatar
Default Re: (theSYNDICATE)
18's are out of the question. The diameter would be bigger than factory which would result in your speedometer being off. Gas milage would go up though
Old Mar 12, 2005 | 11:20 PM
95gsrteg's Avatar
agreed.......get the 16x7's......
Old Mar 13, 2005 | 12:40 AM
Dc2 Powered's Avatar
i'd get some 18' spinners.
i mean how many tegs have u seen with spinners?
Old Mar 13, 2005 | 06:51 AM
shermanyang's Avatar
Default Re: (Solo.)
i'd go with 17's. they look perfect on a teg, and sometimes even look too small. i wouldn't go with anything larger though. i could careless when everyone tells me to go 15" or 16" rims, i just think it makes the car sit too low to the ground and the rims look too small for the car. here's my car with 17's on...do they look too big? tire sizes are 215/40/17 and hopeing to go wider soon.
Old Mar 13, 2005 | 07:52 AM
Dan GSR's Avatar
Default Re: (shermanyang)
15x7
Old Mar 14, 2005 | 08:53 AM
schumi's Avatar
Default Re: (Dan GSR)
Any one using 16x7.5 ?
PreyStayShun
Feb 8, 2011 01:10 PM
Blackout313
Dec 13, 2009 05:59 AM
silverSOHC
Jan 3, 2007 12:00 AM
Racermech
Oct 5, 2005 11:44 AM
PNB
Honda S2000
11
Nov 28, 2004 03:32 PM
