will lca's from 2000 gsr fit ek?
Old Mar 12, 2005 | 12:33 PM
yoej8's Avatar
Default will lca's from 2000 gsr fit ek?
i searched already and asked around, I did not find any answers.
so any answers will help.
im looking to add a gsr swaybar in my 98 civic ex and i just want to make sure that the lca's would be interchangable.
Thanks in advance.
Old Mar 12, 2005 | 12:50 PM
Unjockable's Avatar
New User
Default Re: will lca's from 2000 gsr fit ek? (civek)
integra LCAs don't fit EKs.
Old Mar 12, 2005 | 01:55 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
u didnt mention if u were installing front or rear sway bars. I know the rear LCA's off a GSR wont work at all. I'm not sure about the front though.
Old Mar 12, 2005 | 07:46 PM
yoej8's Avatar
damn oh well thanks alot anyway.
Old Mar 12, 2005 | 09:44 PM
rukawa1one's Avatar
Default Re: (civek)
u can run the rear sway bar off a 99-00 civic SI though, straight bolt on, cuz ur LCA's already have the holes
Old Mar 12, 2005 | 10:02 PM
yoej8's Avatar
yeah i found a lot of info on that already, i think i will be going with that just cause its easy, maybe later on ill upgrade. i was going to use it for autocross but i guess ill use the si bar as a base. Thanks for all the replies, helps a lot.
i actually put a bid on ebay for a gsr swaybar its up to 70 right now so if anyone wants to outbid me so i dont have to resell that sucker, you're all welcome. at honda-acura parts salvage yard in chula vista, the gsr swaybar with endlinks and also lca's sell for 120 so yeah good deal. right there.
http://cgi.ebay.com/ebaymotors...=WDVW
Old Mar 12, 2005 | 10:32 PM
gabebauman's Avatar
Default Re: (civek)
But won't the gsr sway bar work if he gets Si endlinks?
Old Mar 12, 2005 | 11:34 PM
rukawa1one's Avatar
Default Re: (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">But won't the gsr sway bar work if he gets Si endlinks?</TD></TR></TABLE>
I think the actual bar is the same, and the brakets that bolt up to the subframe may be the same, but ya the endlinks definitely have to be from the 99-00 SI.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civek &raquo;</TD></TR><TR><TD CLASS="quote">yeah i found a lot of info on that already, i think i will be going with that just cause its easy, maybe later on ill upgrade. i was going to use it for autocross but i guess ill use the si bar as a base. Thanks for all the replies, helps a lot.
http://cgi.ebay.com/ebaymotors...=WDVW</TD></TR></TABLE>
Thats a RIP! I got my SI sway bar for 50 complete with endlinks from a junkyard. That was cool until I got the 22mm ITR bar with beaks kit now
Old Mar 13, 2005 | 12:00 AM
gabebauman's Avatar
Default Re: (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">I think the actual bar is the same, and the brakets that bolt up to the subframe may be the same, but ya the endlinks definitely have to be from the 99-00 SI.</TD></TR></TABLE>
That's what I thought
Old Mar 13, 2005 | 12:06 AM
SOHC4life 96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">Thats a RIP! I got my SI sway bar for 50 complete with endlinks from a junkyard.</TD></TR></TABLE>
I got my Si sway bar w/ endlinks for $30 from a local h-t member. I will eventually move up to the 22mm ITR bar, but I'm happy with my puney Si one right now.
panda'eg
May 27, 2004 09:01 AM
jlamaster
Oct 13, 2003 12:15 PM
fcuked
Jul 13, 2003 05:28 PM
ransack
10
Jun 18, 2003 12:50 PM
gubo22
Nov 12, 2001 06:56 AM
