EP3 Greddy Turbo
Old Mar 12, 2005 | 10:26 AM
EP3tune2RULE's Avatar
Default EP3 Greddy Turbo
Does anyone know where to find the dyno chart for EP3 with Greddy Turbo running on a stock block. I've looked on Greddy website and all they had was the installation manual. I want to know the actual Hp and Tq to the wheels.
Old Mar 12, 2005 | 04:22 PM
B18CXr's Avatar
Default Re: EP3 Greddy Turbo (EP3tune2RULE)
https://honda-tech.com/zerothread?id=1143905
NOTE:
NOT dynojet numbers, should be around 15% higher on a 248C
10.5psi, stock motor, off the shelf Greddy kit with FMIC
Old Mar 12, 2005 | 06:46 PM
jdmvtec28's Avatar
Default Re: EP3 Greddy Turbo (B18CXr)
Dynopack
http://www.boosted-hybrid.com/viewtopic.php?t=1799
Old Mar 13, 2005 | 12:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1143905
NOTE:
Thanks! but what if you're running only 5-6 lbs of boost
Old Mar 13, 2005 | 07:32 AM
lessthndan's Avatar
at 6.5psi it adds +/- 50whp. Also, Greddy Turbo Kits do not come with an intercooler, it is sold seperate.
Old Mar 13, 2005 | 11:14 AM
aspec04t's Avatar
These are pretty good numbers from a plug and go kit. If you want t squeeze every single bit of HP and trust me there is more to squeeze out get a K-pro.
Old Mar 13, 2005 | 03:06 PM
jdmvtec28's Avatar
Default Re: (aspec04t)
The dyno graph from Evan's Tuning is using a K-Pro
Old Mar 13, 2005 | 04:15 PM
Default Re: (jdmvtec28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec28 &raquo;</TD></TR><TR><TD CLASS="quote">The dyno graph from Evan's Tuning is using a K-Pro</TD></TR></TABLE>
So If I'm using just the Reflash, I can only expect lower results. What are the major differenes between the K-Pro and Reflash besides that fact that for K-Pro, you can use the software to change the settings. Thanks for the info guys.
Old Mar 13, 2005 | 04:52 PM
jdmvtec28's Avatar
Default Re: (EP3tune2RULE)
My understanding of the 2 systems are one is generic... more or less taylored to be interchangable with a wide variety of parts, where if you go with the K Pro your tuner can fine tune the ecu to the exact modifications you have done.
Old Mar 14, 2005 | 08:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec28 &raquo;</TD></TR><TR><TD CLASS="quote">My understanding of the 2 systems are one is generic... more or less taylored to be interchangable with a wide variety of parts, where if you go with the K Pro your tuner can fine tune the ecu to the exact modifications you have done.</TD></TR></TABLE>
Oh, I see what you mean, it make sense the way you put it. Thanks alot!
Dunkinuts
Honda Civic (2006 - 2015)
Jul 29, 2007 09:45 PM
powerls
Dec 23, 2003 11:27 AM
BolivianFuego
Sep 10, 2003 07:35 PM
Sleeping4drLS
May 27, 2003 09:35 PM
darkvader
Oct 6, 2002 11:05 PM
