OBD1, HONDATA, emissions testing....
they are using a new system here in NH that hooks into your OBD2 computer for emissions testing
problem is....
i have an obd1 s200 unit
how do you guys get around the emissions testing and what not?
i called hondata and they are useless
some recommend to switch my stock ECU back in for the test, but if i do that, i also need to switch the stock injectors which isnt a problem, BUT...my car runs like total **** with the stock ECU and injectors and wont pass emissions like that either
so...what do i do?
thanks for your time
problem is....
so...what do i do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">You realize you're screwed, .... right?</TD></TR></TABLE> lol
Exactly. You have to go back to the stock ECU and injectors. If your car is heavily modified, you have a lot of work to do.
silverbulletgsr
Jan 29, 2004 06:19 AM
