ls vtec = bad night
a friend of mine was getting his ls vtec swap ready.. it was a stock ls block with a stock si head..the block had a hone and new rod bearings.. today he put it together and it ran fine for about 5 minutes.. he took it for a drive and it ran strong better than it did the first time although this time at a stop sign, he heard a loud *** pop he didnt know what it was then about half way home he see's it overheating so he pulls over and puts more coolant in then he hears another pop and there's coolant spilling out the side of the head next to the timing belt.. the head was torqued down it was a 3 layer headgasket, stock b16 head bolts.. we pulled the head of and the headbolts had threads on them from the block..the right left side of the head is fine.. all those threads hold until the middle top bolt, and the rest of those threads just gave up.. how come it only happen on this side?? has this happen to any one?? what might of caused this to happen? thanks guys..
yea there the same length... then how come this ran the first time.. it was in there before with b16 head studs only thing is he bent a rod so he changed it and while the pistons were out it got honed.. could the extra compression do this?
would you mind telling me step by step how you installed those headstuds....i already know what can cause this...just wanna see if my theory is right...im betting the problem is in the install of those headstuds....not the headstuds themselves...
this is how i installed my ARP's
hand screw them(studs) all the way down, if it gets stuck and still have ways to go, then allen wrench it down til it wont go anymore
next, turn the studs back two full turns and put the gasket/head on and torque down.
now this has proven to work for me, and maybe others as well, however please schime(sp?) in if it's not right. it seems logical to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtorTHRUST »</TD></TR><TR><TD CLASS="quote">this is how i installed my ARP's
now this has proven to work for me, and maybe others as well, however please schime(sp?) in if it's not right. it seems logical to me. </TD></TR></TABLE>
you were doing good till
"next, turn the studs back two full turns"
http://www.arp-bolts.com/pages....html
it may of been because their reused, head studs cant be reused but for so long. once they expand and contract they become very weak.
block is fixable. some say helicoils will work, but for me helicoils destroied my block. email this guy, dfeent@netzero.com he fixes head studs with time-serts. he told me $60 bucks, but you have to ship him the block unless your in FL.
golden eagle refered me to him in the past
oh damn, didnt see you are in NJ.
You can bring your block to a shop in PA called ECAM. he already has the tools to fix b series head studs. email me ill give you the shop # chris@autorush.com
