will 9.5" wide slicks fit a crx?
Old Mar 11, 2005 | 08:30 PM
streetrage's Avatar
Default will 9.5" wide slicks fit a crx?
I just bought some 24.5 x 9.5 on 13" Bogarts. Will these fit my rex without hitting the upper control arm?
Alex
p.s. I searched but found nothing....
Old Mar 11, 2005 | 10:03 PM
XXXRacing's Avatar
Default Re: will 9.5" wide slicks fit a crx? (streetrage)
will probably need spacers depending on the backspacing of the wheels. H&R makes some nice ones. I had to use spacers with 8.7" wide rim.
Old Mar 11, 2005 | 11:04 PM
svpAMhatch's Avatar
Default Re: will 9.5" wide slicks fit a crx? (XXXRacing)
u run an 8.7 wide rim? or slick?
Old Mar 12, 2005 | 03:41 AM
XXXRacing's Avatar
Default Re: will 9.5" wide slicks fit a crx? (svpAMhatch)
8.7 wide slick, the M&H 25X8.7X13
Old Mar 17, 2005 | 11:18 AM
streetrage's Avatar
anyone know?
Old Mar 17, 2005 | 12:32 PM
serturbo's Avatar
Do Bogarts even have different back spacing available? All the ones I’ve seen are the same. If a spacer was needed for the specific application, they would include it on the wheel.
Old Mar 17, 2005 | 12:36 PM
JL's Avatar
JL
Default Re: (serturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by serturbo &raquo;</TD></TR><TR><TD CLASS="quote">I’ve</TD></TR></TABLE> thats cool
the bogarts come with (or atleast the ones i have) a spacer that is attached to the wheel, it is "bolted" on, or screwed on, kindof like a brake rotor, they have the phillips head 'screws' that you can use to remove them, but i also have the wheel spacers that go along with them for my 22x9.5x13's and they have been on a crx, integra, and eg civic with no problems. but i actually don't know the width of the wheels. i'll find out.
Old Mar 17, 2005 | 03:49 PM
streetrage's Avatar
well my wheels have a spacer welded in the back... A friend told me that the previous owner welded them in to clear the caliper..
Thanks for all the info so far..
Old Mar 18, 2005 | 11:36 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetrage &raquo;</TD></TR><TR><TD CLASS="quote">I just bought some 24.5 x 9.5 on 13" Bogarts. Will these fit my rex without hitting the upper control arm?
yeah I ran a 22 x9.5"x13 on bogart dragonfly with spacers ... you definitely need extended wheel studs though ...
are you boosting or all motor ?
Greg
Old Mar 18, 2005 | 01:19 PM
ninesecrx's Avatar
Default Re: will 9.5" wide slicks fit a crx? (CHEETAH)
I ran 24.5x9.5x13 inch MH tires on my crx and they didnt hit. I had a 13x8 inch bogart wheel with no spacers and it worked fine.
Old Mar 19, 2005 | 08:11 PM
streetrage's Avatar
Great! Thank you all for your responses!
Old Mar 19, 2005 | 09:39 PM
whatVTEC's Avatar
Default Re: (streetrage)
looks like you're good to go Alex
Old Mar 20, 2005 | 07:38 PM
streetrage's Avatar
you know it daryll! I've been preparing for this race for almost a year! Ive dumped a few more G's in that car, so it better be pretty quick!
S2kGuy07
Honda S2000
May 26, 2007 01:31 PM
fonzy
Nov 13, 2006 01:15 PM
mr. vang
Mar 16, 2006 06:00 PM
yakitori
Nov 21, 2003 10:46 AM
PyroVTEC
Feb 24, 2002 12:41 AM
