how do i get the finagen pin out from my engine bay
how do i get the finnigin(pronounced FIN A GIN) pins out from my engine bay,
it keeps getting stuck between the synchronized chain dampener and the extended alloy
retentioner
please help i need the racecar done for this weekend
tHanks guys your the best
im thinking theres too much phosfate lube in the housing assembly
retentioner
ok thanks guys i did everything that you guys said to do . . . BUT when i changed the blinker fluid i Also changed my headlight fluid and i found gold shaving in the fluid . . . thats right guys i think i spun a headlight bearing . . . NO good guys now i have to change out the whole housing
Sounds like you discombobulated the shank tube. Just torque the rotary line(the one in line with the johnson tube), and use the finkle bar to recombobulate it. Then fill it with A-1 lube, or mix with heinz 57 for better winter time protection.
Dekorum
Apr 27, 2011 01:46 PM
deez nuts
11
Jul 23, 2005 10:51 AM
