Will an OEM speedo drive gear fit on an aftermarket diff?
Old Mar 11, 2005 | 03:38 PM
Atheist's Avatar
Default Will an OEM speedo drive gear fit on an aftermarket diff?
I am having a problem in that I don't know what kind of diff I have in my gearbox. Its some type of LSD, I just don't know who makes it. I have my gear box torn apart trying to figure it out, but I don't have access to a gear press right now. Anyhow, I couldn't get my speedo to work, and when I took my diff out I found out why:
I have no speedo drive gear!
I dont know if an OEM speedo gear will fit, but id imagine it'd probably be different. I purchased an ATS driven gear for $70 directly from ATS and it is smaller (both in height and diameter) than the stock one, I am assuming this is to create a lower ratio to keep the speedo accurate.
However, the gears are helical cut, and are supposed to be in constant mesh. Since it is smaller, I doubt they would touch. If a stock gear would fit, I could put it in with the stock driven gear, but I'd bet my speedo would be way off.
Incidentally, I think that I could enable vtec @ < 20mph in uberdata as a fix for the no speed no vtec. I just want a speedo.
Old Mar 11, 2005 | 07:20 PM
Atheist's Avatar
someone?
Old Mar 12, 2005 | 06:39 AM
Atheist's Avatar
Old Mar 12, 2005 | 07:41 AM
NJIN BUILDR's Avatar
Default Re: (Atheist)
My Quaife diff used the stock gear.As far as I know the gear is only available as part of the oem diff. assembly,not separately.Try http://www.gear-speed.com . They may be able to help you.
Glenn
Old Mar 12, 2005 | 10:41 AM
Atheist's Avatar
Default Re: (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">My Quaife diff used the stock gear.As far as I know the gear is only available as part of the oem diff. assembly,not separately.Try http://www.gear-speed.com . They may be able to help you.
Glenn</TD></TR></TABLE>
mint! I mailed 'em, thanks!
Old Mar 13, 2005 | 10:13 AM
Atheist's Avatar
anyone else?
Old Mar 13, 2005 | 10:34 AM
h22 civic's Avatar
mine fit with my quaife
Old Mar 13, 2005 | 12:10 PM
Atheist's Avatar
good deal keep em comin!
TimeAttackR
Transmission & Drivetrain
Apr 14, 2019 08:28 PM
tarzzan
May 19, 2013 05:33 PM
R2D2
Jun 17, 2002 07:40 AM
