I need help 5 lug on a 2000 ek???
Old Mar 11, 2005 | 02:40 PM
Jdm_honda_ek9's Avatar
Default I need help 5 lug on a 2000 ek???
I need directions or a web page on doing a 5 lug convertion on a 2000 ek (dx). I was going to buy a kit from a JDM ITR. I also want to make sure I get everything.
Old Mar 11, 2005 | 02:42 PM
^CX_d16's Avatar
Default Re: I need help 5 lug on a 2000 ek??? (Jdm_honda_ek9)
not difficult at all.
if you are getting it from a JDM ITR you need 36mm axles, not 32 like your stock ones.also you have to use your stock rear LCAs because the ITR ones are too short.
Old Mar 11, 2005 | 03:55 PM
JDM PRO's Avatar
Old Mar 12, 2005 | 07:15 AM
Default Re: I need help 5 lug on a 2000 ek??? (^CX_d16)
Thank you, it come with the axles. how about the brakes? Since i'm changing to Disk is there anything I need to do with that?
Old Mar 12, 2005 | 08:20 AM
Jon V's Avatar
You will need the rear brake lines and you can get some new hubs from a US spec Acura dealer for a USDM ITR and you can use the more common 32mm axles...
let me know if you need any help I did my swap myself...
Old Mar 12, 2005 | 10:35 AM
Ls_V_TurboSi's Avatar
Default Re: I need help 5 lug on a 2000 ek??? (Jon V)
did the swap in like 4 hours in the freezing cold... Its pretty easy
Old Mar 12, 2005 | 11:03 AM
JDM PRO's Avatar
us spec 5 lug would fit right in? How can you tell if its a us spec?
Old Mar 18, 2005 | 10:04 PM
seros's Avatar
Default Re: I need help 5 lug on a 2000 ek??? (JDM PRO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM PRO &raquo;</TD></TR><TR><TD CLASS="quote">us spec 5 lug would fit right in? How can you tell if its a us spec?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^CX_d16 &raquo;</TD></TR><TR><TD CLASS="quote">not difficult at all.
if you are getting it from a JDM ITR you need 36mm axles, not 32 like your stock ones.also you have to use your stock rear LCAs because the ITR ones are too short.</TD></TR></TABLE>
both will fit perfect ...the only difrance is the hub size on the jdm on is 36mm and the usdm 32mm ..... u can get custom axles for it.... but my convertion comes with them .
Diamond Co
Suspension & Brakes
Mar 16, 2012 07:33 AM
chapagetti
19
Oct 20, 2009 04:02 PM
Boriqua0555
Jun 28, 2007 10:13 AM
2000CivicEK
Jun 27, 2007 08:29 PM
deucedeuceEK9
Apr 17, 2006 05:08 PM
