Honda S2000 Honda S2000
Spoon mono-block caliper
Old Mar 11, 2005 | 12:28 PM
WowOzYouRock's Avatar
Default Spoon mono-block caliper
I used to have Stop-Tech BBK but i took it out the next day i installed it cuz the
bitch is huge and wont clear my Advan RG +45 offset .. Anyway, i was just
wondering if the Spoon mono-block caliper clear my rims ... i search and couldnt fine
anything ... TIA
Modified by Y2K_S2K at 5:01 PM 3/11/2005
Old Mar 11, 2005 | 01:53 PM
revhi's Avatar
Spoon calipers fit with the Spoon rims, and they're not that big, not sure about the offset though.
Old Mar 11, 2005 | 02:02 PM
Default Re: (revhi)
whats the offset of the spoon rims though? and does it clear without any spacers?
Old Mar 11, 2005 | 02:05 PM
tmkpres's Avatar
Default Re: (Y2K_S2K)
to fit the calipers with the SW's you have to run the +35, and the regular SW's are +45.
Old Mar 11, 2005 | 02:12 PM
Default Re: (tmkpres)
but does it clear without spacers though?
if so ... how sure are you?
Old Mar 11, 2005 | 02:15 PM
tmkpres's Avatar
Ill ask one of my buddies he has the calipers and the rims set up. But I am almost postive that he is running the 35 in the front with no spacer.
Old Mar 11, 2005 | 02:20 PM
thanx
Old Mar 11, 2005 | 02:27 PM
Ferrell's Avatar
SW388 +35 will clear the calipers w/o spacers.
Old Mar 11, 2005 | 02:35 PM
Default Re: (Ferrell)
so i guess any rims with +35 offset clears the spoon calipers w/o and spacers??
Old Mar 11, 2005 | 03:00 PM
tmkpres's Avatar
Yep, we just finished talking and he is running the 35 offset with no spacers.
Old Mar 11, 2005 | 06:06 PM
papa5murf's Avatar
go look for some willwoods.. they will fit... you can fit a 6pot caliper under the stock wheels from willwood with the 12.2inch rotor.. with no spacer...
Old Mar 11, 2005 | 06:52 PM
tmkpres's Avatar
Default Re: (03s2kblue)
that big of a rotor on the stock rim ? Wow impressive.
Old Mar 11, 2005 | 08:10 PM
bluesaint's Avatar
BECAREFUL, not any wheel with +35 offset means it will clear the spoon calipers, offset actually only play a small portion of the overall picture. The Spoke designs of wheels plays the most part in determining if you can fit BBK or not.
IE. my +45 offset 17inch clears without spacers, but another wheel, say ce28, will not even come close cause the spoke bends inwards to the inner lip.
Old Mar 11, 2005 | 08:50 PM
silver2dr's Avatar
Default Re: Spoon mono-block caliper (Y2K_S2K)
How much did you pay for the Stoptech's? what kind of difference is there between them and the stock ones?
Old Mar 12, 2005 | 11:05 AM
Default Re: Spoon mono-block caliper (silver2dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver2dr &raquo;</TD></TR><TR><TD CLASS="quote">How much did you pay for the Stoptech's? what kind of difference is there between them and the stock ones?</TD></TR></TABLE>
a whole LOTalot of difference ... size, performance its just different from the stock
caliper .. too bad it wont clear my Advans...
Old Mar 12, 2005 | 12:53 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">
caliper .. too bad it wont clear my Advans...</TD></TR></TABLE>
not even with a spacer?
Old Mar 12, 2005 | 01:05 PM
Default Re: Spoon mono-block caliper (03s2kblue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">
not even with a spacer?</TD></TR></TABLE>
ohh yes , it did clear after i put 15mm spacers but it looks like a mexican mobil cuz the tires are 1 inch stick out from the fender
Old Mar 12, 2005 | 05:48 PM
Nishant's Avatar
ohh yes , it did clear after i put 15mm spacers but it looks like a mexican mobil cuz the tires are 1 inch stick out from the fender </TD></TR></TABLE>
apparition
Feb 24, 2009 04:39 PM
oldschoolflava
Mar 5, 2007 01:43 PM
ABTDer
Mar 22, 2003 02:31 PM
purplehazek4
Sep 9, 2002 03:42 PM
itrsport.com
May 17, 2002 08:17 AM
