o2 sensor for b16
I planning on buying a header. I know i have to relocate the o2 sensor or weld a bung. I heard on another forum that I can use a 98-01 accord 4 plug o2 sensor since it is a little longer it will reach the bung on the the aftermaket header. anyone know about this or used that particular one.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h »</TD></TR><TR><TD CLASS="quote">You don't have to relocate. Just have an exhaust shop weld 2 o2 bungs on the header in the stock B16 header locations. </TD></TR></TABLE>
that is correct
You only use a 4-wire O2 if you're running an OBD1 setup. Otherwise you stick with the 2 single wire O2's
that is correctYou only use a 4-wire O2 if you're running an OBD1 setup. Otherwise you stick with the 2 single wire O2's
