ITR muffler dyno - 2.0L B20 Engine with ITR Cams.
Well seing it was designed for a Stock 1.8L ITR Engine, and you are running a 2.0L with other mods, and also dont you have JUN Cams? What were you expecting, I would have told you it would be a holdback with your setup. I would say to have a Custom 2.5" system made for the car.
Stock 97 Spec R cams
I know..Im not saying its bad for a stock like motor..just sharing the dyno results on my motor.
Not a 2.0L B20
Not a surprise, the ITR muffler is only 2-1/16" OD tubing at the inlet. Did you get rid of the Tanabe bottle neck at the B pipe?
SMSP - Who thinks we should have run a few of the JDM type headers with the stock exhaust in the header test.
And when are you Americans switching to the metric system?
Metric system
Metric system
A few often used numbers:
2.5" = 63 mm
2-1/16" = 52 mm
I think it's time to change that signature punk...
I think you should mention that you changed to the ITR muffler for other reasons; I remember you saying that your previous exhaust was way loud and hurt your ears.
Yea that is why I did change to the ITR muffler originally...
But after seeing the loss in power...I think Ill put up with the loudness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [HrZn »</TD></TR><TR><TD CLASS="quote">4life]Back from the dead.
The dyno pic isn't showing up...I was just wondering if any of you remember what the difference in power was. Thanks</TD></TR></TABLE>
Don't recall exactly but it was a pretty good amount IIRC. But as stated in the thread, it was on his modified B20VTEC so it's pretty useless from a normal ITR owners standpoint.
ek44
Dec 11, 2006 10:08 AM
X2BOARD
Apr 5, 2004 09:28 PM
