Possible Problem with Comptech Flywheel...It's Baffling
Old Mar 11, 2005 | 10:54 AM
CPR's Avatar
CPR
Default Possible Problem with Comptech Flywheel...It's Baffling
I had some tranny issues a while back causing the Acura dealership to replace some gears for me. At the time they did this, I had them install a JDM final drive and Comptech aluminum flywheel. This was paired with my stock ITR pressure plate/clutch at the time. The gear replacement didn't fix the issue so they dropped my tranny again to replace the stock ITR pressure plate/clutch with brand new ones. When they tried to mate my comptech flywheel to the new pressure plate, the pegs on the FW didn't match up with the holes on the PP. So I had them reinstall my stock ITR flywheel and that had no issues matching up with the new pressure plate.
Any ideas what caused this? I've included pics of my comptech flywheel with measurements from peg to peg. The distance between pegs aren't identical and I'm not sure if this is the problem or not. Anybody have a B18C5 pressure plate and/or flywheel they can take the same measurements on? TIA
Old Mar 11, 2005 | 10:58 AM
Dan GSR's Avatar
Default Re: Possible Problem with Comptech Flywheel...It's Baffling (CPR)
well, the PP will only go on one way
since the peg locations are assemetrical
I hope they tried to rotate the PP to put it on
Old Mar 11, 2005 | 10:59 AM
BlueR's Avatar
Default Re: Possible Problem with Comptech Flywheel...It's Baffling (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">I hope they tried to rotate the PP to put it on</TD></TR></TABLE>
chris, wouldn't it be hilarious if they didn't?
Old Mar 11, 2005 | 11:08 AM
Chris N's Avatar
Default Re: Possible Problem with Comptech Flywheel...It's Baffling (BlueR)
LOL... was thinking the same thing when I read the original post and Dan's post....
Chris #2 - who thinks/hopes that is the issue.
Old Mar 11, 2005 | 11:09 AM
thk's Avatar
thk
Members Only
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">chris, wouldn't it be hilarious if they didn't? </TD></TR></TABLE>
And it really shouldn't matter too much about if it's B18C5 specific since I thought all B series had compatible and interchangable clutch/drivetrain components.
It would be funny though (what Dan said).
Old Mar 11, 2005 | 11:29 AM
splitime's Avatar
Default Re: Possible Problem with Comptech Flywheel...It's Baffling (thk)
Pretty sure they didn't rotate it like Dan said.
Old Mar 11, 2005 | 12:06 PM
Mike M's Avatar
Founding Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">
They do, I'd put money they didn't try rotating it. lol
PS Thats why its good to stay away from some dealerships Service dept's
Old Mar 11, 2005 | 12:24 PM
CPR's Avatar
CPR
I guess it's not so baffling after all. I saw with my own eyes how it wasn't meshing together. If I had known the pegs were not identically spaced, I would have tried rotating it myself but there's a reason I'm not a mechanic. Thanks for the quick responses fellas.
Hey Dan (Dan GSR), I'm not sure if Marc has mentioned it to you but I'm planning on going to NYC when it warms up to hire your services. I'll bring the car, kalbi, beer and funds. You wouldn't have any spare B18 pressure plates laying around for me to try my flywheel against would you?
Old Mar 11, 2005 | 12:26 PM
TPB's Avatar
TPB
Default Re: Possible Problem with Comptech Flywheel...It's Baffling (Mike M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike M &raquo;</TD></TR><TR><TD CLASS="quote">
PS Thats why its good to stay away from some dealerships Service dept's </TD></TR></TABLE>
Especially when you ask them to install aftermarket parts. Some service departments really shy away from that possibly due to liability issues.
i stopped taking my car to the dealer years ago because they consistently screwed up on torque specs. If they messed up on something that simply, I took it as an indication that the people working on the car didn't care too much about what they were doing. Now I know that the work is done right because i'm taking the care and time to do so.
CPR's Avatar
CPR
It would have been hillarious if it didn't cost so damn much to do tranny work.
Old Mar 11, 2005 | 12:36 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CPR &raquo;</TD></TR><TR><TD CLASS="quote"> I'm planning on going to NYC
You wouldn't have any spare B18 pressure plates laying around for me to try my flywheel against would you?</TD></TR></TABLE>
ready whenever you are
and yes, i have a clutch/pp laying around
Old Mar 11, 2005 | 12:38 PM
BlueR's Avatar
j00 didn't quote the most important part!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CPR &raquo;</TD></TR><TR><TD CLASS="quote">I'll bring the ... kalbi, beer and funds. </TD></TR></TABLE>
Old Mar 11, 2005 | 12:43 PM
RTW DC2R's Avatar
are you kidding me that they didnt try to rotate the PP or FW to line up the pegs? Ive only installed 1 clutch in my entire life (just a few weeks ago) and I knew to atleast TRY to rotate it when the pegs didnt line up the first time. Its common sense! :BFH:
Old Mar 11, 2005 | 01:02 PM
thk's Avatar
thk
Members Only
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">ready whenever you are
and yes, i have a clutch/pp laying around</TD></TR></TABLE>
Ditto. At least, I think I still have it lying around.
Old Mar 11, 2005 | 02:28 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Possible Problem with Comptech Flywheel...It's Baffling (TPB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TPB &raquo;</TD></TR><TR><TD CLASS="quote">
Especially when you ask them to install aftermarket parts. Some service departments really shy away from that possibly due to liability issues. </TD></TR></TABLE>
I thought Acura service departments were supposed to be ok with Comptech parts?
Old Mar 11, 2005 | 02:35 PM
Bbasso's Avatar
Default Re: Possible Problem with Comptech Flywheel...It's Baffling (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">I thought Acura service departments were supposed to be ok with Comptech parts?</TD></TR></TABLE>
HA!
Old Mar 11, 2005 | 02:44 PM
Splat's Avatar
Default Re: Possible Problem with Comptech Flywheel...It's Baffling (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
HA!</TD></TR></TABLE>
WTF eh? The dealership I bought mine from in Chapel Hole has Comptech banners hanging in the damn service bay, and brochures for Comptech parts in the lobby. Are Acura and Comptech no longer in bed together?
&lt;-- Confused.
Old Mar 11, 2005 | 02:55 PM
Bbasso's Avatar
When I had issues with the bearings in the tranny the dealer I bought the caR from said it was due to the Comptech FW ...
I said prove it. but of course they could not.
Old Mar 11, 2005 | 02:57 PM
Splat's Avatar
Gotcha. That's the bad thing about dealers - they don't all read from the same book.
Got a good story about a friend's F150 and the local Ford establishment, but State's about to play
Old Mar 11, 2005 | 03:44 PM
uNF$@#!'s Avatar
whats kalbi? im a newbie
Old Mar 11, 2005 | 04:00 PM
slackeR1366's Avatar
Default Re: Possible Problem with Comptech Flywheel...It's Baffling (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">whats kalbi? im a newbie </TD></TR></TABLE>
whatever it is, sounds good enough to watch Dan work and drink
im in
Old Mar 11, 2005 | 04:16 PM
thk's Avatar
thk
Members Only
Korean BBQ.
Old Mar 11, 2005 | 05:31 PM
BlueR's Avatar
Default Re: Possible Problem with Comptech Flywheel...It's Baffling (R1366)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R1366 &raquo;</TD></TR><TR><TD CLASS="quote">
im in </TD></TR></TABLE>
watching and drinking is good with me too
Old Mar 11, 2005 | 06:19 PM
uNF$@#!'s Avatar
if kalbi=korean BBQ then i'm happy to watch as well
Mmmmm
Old Mar 11, 2005 | 07:00 PM
Dan GSR's Avatar
dun worry guys, come May, we'll have our 2nd annual R-Speed spring BBQ
NA4sho
Honda Civic (2006 - 2015)
Oct 9, 2006 10:32 AM
Andrie Hartanto
May 14, 2004 11:52 AM
HondaRcB
Feb 28, 2004 02:02 PM
Money Hou$e
Jun 1, 2002 05:23 PM
