distributor for dpfi to mpfi conversion
which distributor can I use for my conversion, can i use the stock one off of the d15 ? I am installing a d16a6 with a d16y8 manifold, RC injectors, ported head,+ web cam. I also need an ECU which one is the best to use (I will most likely have it chipped). I have si wiring harness to use. THANKS !
ID_ten_T
Jan 15, 2004 04:17 AM
