Back up Lights
Old Mar 11, 2005 | 07:41 AM
TheStew913's Avatar
Default Back up Lights
I really need help with this, I've got a 94 EX and whenever I throw the car into reverse the lights in the back don't light up for me. I've checked the fuse box and I've checked both of the lights and I can't figure out how to fix the problem. PLEASE HELP!!!
Old Mar 11, 2005 | 07:57 AM
Filthy Focker!'s Avatar
Default Re: Back up Lights (TheStew913)
So you are convinced that the lights work, right?
And you are convinced that power is reaching those lights, right?
If the bulbs are good, and are not lighting up, you have a problem in the back-up light circuit. Maybe the back-up switch. What happens when you wiggle the stick shift, do they at least blink a bit?
fs
Old Mar 12, 2005 | 10:10 AM
TheStew913's Avatar
Default Re: Back up Lights (filthy_shovel)
No, I don't think they go on at all.
Old Mar 12, 2005 | 04:29 PM
BaddMo2002's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheStew913 &raquo;</TD></TR><TR><TD CLASS="quote">No, I don't think they go on at all.</TD></TR></TABLE>
think? make sure your bulbs do not light up and I'm assuming you've already tried replacing the bulbs? did these reverse lights used to go on before while the car was under your ownership?
Old Mar 12, 2005 | 11:00 PM
TheStew913's Avatar
Default Re: Back up Lights (BaddMo2002)
I've checked both of the bulbs, and they are fine. Besides the odds the odds of both of the lights going out at the same time is very unlikely. And yeah, they have worked under my ownership.
Old Mar 13, 2005 | 08:01 PM
jamey220's Avatar
check ur connections at the transmission there's supposed to be a yellow and a green wire, make sure that they are pluged up.
Old Mar 14, 2005 | 04:22 PM
TheStew913's Avatar
The power is not reaching them I think because it is unplugged in the back, Cause the blue wire isn't plugged into anything in the trunk of the car while the two black ones are plugged into something.
mikeSMASHES
Feb 10, 2010 12:41 PM
Fall_out_boy_99
Jan 13, 2010 01:23 PM
NAturalEk9
Sep 23, 2009 04:45 PM
Mfoehrkolb
Sep 22, 2008 05:56 PM
xionl1350
Honda S2000
12
Jul 17, 2008 05:16 PM
