brakes making noises
after installing the crossed drilled rotors, my car makes these weird noises. When i am driving i can hear like the brakes are scratching the rotor? or is it somethin else?
ANYONE had this problem b4? its getting me pissed, wanted to know wat to look for b4 i take it off again
bremco rotors + ebc pads on 95 gsr fronts
Yep, Same problem. Has it been windy recently? Whenever it get windy for me dirt and grim will build up over time and will get in between your brakes and rotors. It will sound like crap until it goes away!
did you use the brake lube and lube teh slides when installing the new pads?
I've used both brembo rotors and ebc pads before and never had any issues like that.
One problem you have is that you bought an EBC.
I prefer Axxis Ultimates. You may have one of one of the clips that hold the pads in crooked. I did that once and it made all sorts of noise until I fixed it. HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nygsr »</TD></TR><TR><TD CLASS="quote">u should just burn out all day, warm up the rota, than it well be good in use</TD></TR></TABLE>
i like that.. is it true?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg »</TD></TR><TR><TD CLASS="quote">did you use the brake lube and lube teh slides when installing the new pads?
redrocket_ej1
Dec 9, 2009 04:18 PM
skimeast1982
Oct 18, 2006 04:31 AM
