FAL 108 in pusher fan mode, do I flip fan around or cross wiring?
Old Mar 11, 2005 | 01:58 AM
BlueShadow's Avatar
Default FAL 108 in pusher fan mode, do I flip fan around or cross wiring?
Hi guys,
I just got done installing my FAL on my EG half rad however I'm a little confused on the FAL 108. I want to make it work in pusher mode, and I thought to do that you had to flip the fan around. Well I did that I'm pretty sure the fan blades looked the same, or maybe I was just looking at it crosseyed.
But one other thing I found out was that the fan motor can spin either clockwise or CCW. I used a a tiny 9V battery to see if I could tell which way the air was flowing. Just for the hell of it I switched the pos and neg wires on the battery and the fan started spinning the other way. Is this another way the fans can be used? can I use it this way,or will using it like this cause damage to the fan motor?
TIA
Old Mar 11, 2005 | 06:17 AM
PrettyLude's Avatar
yes it could be used that way
Old Mar 11, 2005 | 09:02 AM
BlueShadow's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">yes it could be used that way</TD></TR></TABLE>
cool, so I guess if I leave the fan on like it came out of the box (puller mode) and just switch the wiring then it would make a pusher fan?
Old Mar 11, 2005 | 11:48 AM
h22 civic's Avatar
Default Re: (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">
cool, so I guess if I leave the fan on like it came out of the box (puller mode) and just switch the wiring then it would make a pusher fan?</TD></TR></TABLE>
absolutlly just switch wires
Bldg1023
Apr 9, 2017 04:34 PM
Hex213
10
Feb 16, 2013 02:20 PM
slow sol
Mid-Atlantic (Sales)
Sep 18, 2009 04:58 AM
cpmike
Jul 20, 2007 04:36 PM
