i need a list of everything needed
Old Mar 10, 2005 | 09:38 PM
StraightCivic's Avatar
Default i need a list of everything needed
Hello,
Its me again i just want a list of everything (parts) and I mean EVERYTHING i need for my b18c swap into the 89 hatch dx. Its time for me to buy the motor and everything else. Ill have about 4K on fri and i wanna buy everything. I would appreciate links. This includes to put the hydrolic tranny in the hatch as well. and its dpfi.
thanks.
so far i got that i need:
odb1 jumper harness
dx to b18c harness conversion
efb2 motor mount kit
and b18c1 complete change over swap from hmotors.
Old Mar 10, 2005 | 10:09 PM
Burlyirishdude's Avatar
Default Re: i need a list of everything needed (StraightCivic)
dpfi--->mpfi conversion....
Hydro tranny-->cable tranny...unless you have a different B series cable tranny.
Wiring chart printout for the ecu you are using and all the new Connection you need.
All i can say is.....Tkae pics...and torque everything down correctly.....and put away another 1G b/c something can and usually will go wrong.... other then that....good luck dude
Old Mar 11, 2005 | 04:33 AM
Default Re: i need a list of everything needed (Burlyirishdude)
where can i get the hydro to cable tranny conversion? i looked on hasport and all i found was the motor mount kit to make a hydro tranny work.
Old Mar 11, 2005 | 06:43 AM
Well that's what it is....The haspsort kit is what makes the Hyrdo possible in a cable chasis.
But you can always get a J1, s1, y1, ys-1. or any other b series tranny and just bolt right up to your B block.
Old Mar 13, 2005 | 07:02 PM
i think this swap is easier than the b16 swap cuz i mean u gotta wire up a resister box and **** like that for the b16 but for this u only need the motor mount and hydro kit and the special wires and **** from rywire and the ecu layout to remove pins and ****.
thanks a lot guys. The perormance shop that is gonna do it is gonna call me monday to tell me a price ill let yall know what he tells me. thanks a lot.
Old Mar 13, 2005 | 07:16 PM
coot_er's Avatar
its not easier than the b16 its just not much harder. its basically everything you have to do to put in a b16 plus convert to obd 1.
do you have shift linkage?
not sure what clutch cable you need
not sure which throttle cable you need
do you have the obd0-obd1 conversion harness? (i THINK your engine is obd1)
im not sure what kind of speed sonsor that comes with and what your going to use
Old Mar 13, 2005 | 07:25 PM
99teggsr's Avatar
Default Re: i need a list of everything needed (coot_er)
From Ryans (rywire) droppedcrxsi.com page:
What kind of things are needed for the swap?
-B18c engine
-Obd1 P72 ecu, or P28 (chipped)
-engine mounts with cable to hydro conversion (Hasports)
-90-93 B18a/B16a mount bracket between the t-belt
-90-93 integra rear tranny mont bracket (T shaped bracket)
-B series tranny (cable or hydro)
-shift linkage 90-93 integra (must be shortened) or hasport (direct fit)
-90-93 integra axles/int shaft, or 94-95 GSR axles/int shaft
-OBD 0 to OBD 1 conversion harness
-OBD 1 vtec distributor
-Obd 1 injectors (eliminate injector box), or obd 0 injectors (keep box)
-94 GSR upper radiator hose trim to fit
-90 integra lower radiator hose trim to fit
-CRX front heater hose
-Cut to length coolant hose for rear heater hose
-90-93 integra throttle cable
-Type R throttle cable bracket or B16a gen 1 (with skunk2 manifold)
-B18c exhaust manifold will be too short, take a trip to the exhaust shop when done (or use a b16a unit)
-4 wire 02 sensor
-Skunk2 intake manifold (recomended), positions t-body in proper location for intake.
-Lots of wiring challenges, repining, lengthening, adding wires (02, knock,IAB, vtec, exc...)
goto droppedcrxsi.com , ryan walks through nearly every step of the swap
JPM98EK
Transmission & Drivetrain
Mar 21, 2010 08:00 PM
jredhonn
Apr 11, 2007 04:20 PM
TeamRedline89Hatch
13
Nov 18, 2005 12:18 AM
X_Josh411_X
Oct 1, 2005 04:28 PM
StraightCivic
Mar 10, 2005 08:47 PM
