when getting the knock sensor code would vtec not engage
wtf? u can still pop vtec if u have no knock sensor. vtec wont pop if u dont have the right oil pressure, ur speedo's not working, coolant temp sensor is not working. and also if u have a bad vtec solenoid or wiring to the ecu. als the ecu migh be a problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordRacing »</TD></TR><TR><TD CLASS="quote">I had my knock unplugged for a day or two .. and anything over like 50mph or some high reving .. your going right into limp mode and your not going over like 2500 rpm ..</TD></TR></TABLE>
yup
yup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicsib18c5 »</TD></TR><TR><TD CLASS="quote">ok fact, ks will cause v-tec not work if your running obd2. but most guys run obd1 and obd0 so there is no ks present in obd0 & 1</TD></TR></TABLE>
obd1 has KS........
obd1 has KS........
ntoxicatedtigah
Jun 24, 2009 02:56 PM
salman
Nov 18, 2008 05:27 AM
Raunch
Nov 8, 2003 10:05 PM
