Planning to do a mini me(HELP!!)
Old Mar 10, 2005 | 08:23 PM
Reego.'s Avatar
Default Planning to do a mini me(HELP!!)
like the title says Im planning to do a mini me swap, currently I have the obd0 to obd1 harness a d16z6 vtec head and a complete d15b7 engine,what else will I need in order to make this work,I know I will have to convert from dpfi to mpf.Im currently collecting parts for that, I just want the engine to be reliable even If I spend a couple extra bucks.
Old Mar 10, 2005 | 08:38 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Planning to do a mini me(HELP!!) (Jdm-official)
http://www.geocities.com/joeyp....html
Old Mar 11, 2005 | 11:45 AM
Reego.'s Avatar
Default Re: Planning to do a mini me(HELP!!) (sanimalp)
so it is possible to mate a d15b7 block with a d16z6 head?
Old Mar 11, 2005 | 12:16 PM
vegaskurt's Avatar
I've heard you can do the swap on any d series motor. Just as long as its a 16 valve engine to start with.
Old Mar 11, 2005 | 04:23 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Planning to do a mini me(HELP!!) (vegaskurt)
yes. you can do it with non-16 valve engines too, but you have to swap pistons. the only difference on the d15 v. the d16 is the crank. you could stroke a d15 by putting a d16 crank in it. but the block is the same.
Old Mar 11, 2005 | 04:32 PM
Aragorn's Avatar
There's a super Mini-me write up, don't know if you've read it:
https://honda-tech.com/zerothread?id=635580
Old Mar 11, 2005 | 07:19 PM
Redline130's Avatar
While you are building the mini-me, I would also put in a new water pump, thermostat, and of course fresh oil. You will also need a VTEC head gasket (D16Z6 or D16Y8, Y8 one is supposedly cheaper), and a D16Z6 timing belt. Also, don't forget to pull out the oil control jet in the B7 block. It is located between cylinders 2 and 3, on the firewall (rear) side of the motor. Good luck.
Old Mar 11, 2005 | 09:10 PM
Reego.'s Avatar
Default Re: Planning to do a mini me(HELP!!) (Redline130)
when you say "oil control jet" you mean that lil plug in the picture right?
also what ecu can I use?
Old Mar 11, 2005 | 10:54 PM
bryse68's Avatar
use a 1.6 block, put the flat top d15 pistons, with a d16z6 head, with a y8 intake manifold and header, should be pretty good. I have a d15 wtih a z6 head, headers, exhaust, and its decent. You cant fit the d16 crank in the d15 block, the journals are different, the only way is if you machine the d15 block
Old Mar 12, 2005 | 02:30 AM
NikoZai's Avatar
Default Re: Planning to do a mini me(HELP!!) (bryse68)
for your DPFI to MPFI conversion, see Rywire.com
We can convert your DX harness for you and you can purchase the parts from us. All you need to do is send us your DX harness. If you send your O-1 jumper, we'll solder the pigtail wires together for you on a firewall quick disconnect like factory wiring.
ak12gage
Jan 28, 2017 11:40 AM
TunerKid4lyf
Jun 4, 2013 04:58 PM
Snail Tuning
Sep 5, 2003 12:48 AM
Snail Tuning
Sep 4, 2003 07:02 AM
