Whats the name of this part?
It connects the headers and cat. converter....do they have a shorter version of it? I installed the dc sports headers for my car...it aligns up and everything..and i can push the cat toward the headers to fit snugly...but the stock whatever part that is ..is too long...so i need shorter one? and also shorter spring thingies that compress between them...haha sorry for my newbie slang....also...I could only bolt 7 out of 9 bolts on top of the headers..the 7 bolts are tight..is it still ok? ..thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam »</TD></TR><TR><TD CLASS="quote">there exhaust bolts. They have the spring so they dont rattle loose. Just use regular bolts.</TD></TR></TABLE>
no, they have springs rather than the exhaust using a flexpipe
no don't use regular bolts you will prolly destroy your exhaust, It's designed to move around since hondas don't have flex sections in their header.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WestEM1 »</TD></TR><TR><TD CLASS="quote">is it ok if i have 7 out of 9 bolts on top of the headers on?</TD></TR></TABLE>
im pretty sure theres 9 for a reason get the other 2 on there or expect some exhaust leaks.
i got a question, is it ok to tighten up the exhaust bolt too tight?
some how when ever i am at the 1st gear my exhaust rattle like a ****!!
oh yeah,,, i spent $60 on two sets of bolts and springs at HONDA dealer, so just get at NAPA is cheaper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictyper96 »</TD></TR><TR><TD CLASS="quote">i got a question, is it ok to tighten up the exhaust bolt too tight?
oh yeah,,, i spent $60 on two sets of bolts and springs at HONDA dealer, so just get at NAPA is cheaper.</TD></TR></TABLE>
Probally your cat heatsheild.
http://www.slhonda.com
go to parts.. click on yes.. and the rest is self explanatory
click on the number and it will tell the name and part number..
i took my car to the muffler shop and they said it is not the heat shield, and they could don't find where the problem is.....the rattling sound is killing me....it is getting worse and worse
I just had the exhaust shop add in a piece of flex pipe when they did my exhaust but if you are not redoing your exhaust get the bolts again. And yes you need all 9 of the exhaust bolts/studs I am assuming you mean the ones that hold your exhaust mani to your head. They are cheap bolts/studs and it will keep exhaust from leaking.
do any of u guys know what size the [spring, flexible joint] and the [Bolt A, Flexible joint] are for stock? ...heh I finally know the technical names now
Lorolla
Aug 11, 2004 05:52 PM
