I got the Skunk 2 cams (Type 2 and 3) in stock now...testing commences...
Guest
Posts: n/a
I am probably going to test out these cams on a built GSR motor that makes like 208WHP with Jun 3's.
I just measured all of the types of cams, and I have to say, the Type 2's look like almost exact copies of the JUN type 3's. Looks like they have slightly more duration, and the primaries don't have the same duration also.
so....to have as much fun as we can here on this board....lets all GUESS the results on the 208 WHP GSR with JUN 3's.
I will take the first stab at it.
JUN 3 208 WHP
S2#2 210 WHP
S2#3 215 WHP
And try that. BTW, that SKunk 2 Type 3 is one large large lift cam. Only a few kinds of springs will take it...beware...beware.
Jeff
JUN 3 208 WHP
S2#2 210 WHP
S2#3 215 WHP
Jeff
maybe they will just break like before?? time will tell
.....looking at their specs, they look like they took jun3 specs and added .1mm more lift on the lobes.
how original
[Modified by Black R, 12:18 PM 1/23/2002]
Jun Type 1
INTAKE lift - 10.9 mm, duration - 265.3 @ 1mm
EXHAUST lift - 10.0 mm, duration - 268 @ 1mm
Jun Type 2
INTAKE lift - 12.0 mm, duration - 266.6 @ 1mm
EXHAUST lift - 10.9 mm, duration - 265.3 @ 1mm
Jun Type 3
INTAKE lift - 12.0 mm, duration - 265.3 @ 1mm
EXHAUST lift - 11.5 mm, duration - 265.3 @ 1mm
Skunk2 cams
Stage I
INTAKE lift- 11.58 mm, duration 252 @ 1mm
EXHAUST lift - 10.9 mm, duration 249 @ 1mm
Stage II
INTAKE lift- 12.07 mm, duration 265 @ 1mm
EXHAUST lift - 11.6 mm, duration 256 @ 1mm
Stage III
INTAKE lift- 12.7 mm, duration 273 @ 1mm
EXHAUST lift - 11.5 mm, duration 273 @ 1mm
Jun Type 2
Jun Type 3
Skunk2 cams
Stage I
Stage II
Stage III
Max lift and duration is only a small part of a cams performance. Don't forget about the "area under the curve" that so many of you guys talk about. If just increasing lift and duration makes more power than any Joe Blow can start making large lift and duration cams.
I'll wait to see the dyno's before passing judgment.
CB
CB
Jeff I eagerly await the results! Definitely keep me posted.
do i sence some jeal0usy mr b18 yackmaster??
