Intermediate shaft problem
How the hell do you get it back on. I can not get it to go all the way into the tranny. Tried beating the **** out of it and can't get it in anymore, or get it out. It is on a ys1 LS tranny.
Just take it easy with the shaft dude. hehehe sorry ahd to say it....
Ok You gotta make sure you are pulling it at a level angle or the splines will catch and **** your *** up.... Make sure the 3 bolts on the shaft bracket are undone....Pull at a level angle and Viola....should just slide out.....I made sure to not tear the Tranny seal on that side otherwise there's like 4$ down the drain you know....Try and wiggle....try and just get it going and then it should slide out....If all else fails through some 10w-30 on it and tugg on it...
odidipissuoff
Transmission & Drivetrain
Mar 16, 2010 06:45 PM
Circuit Star-29
Mar 6, 2006 12:09 AM
