91 usdm crx SI cluster in 90 civic DX ?????
Old Mar 10, 2005 | 06:10 PM
turboartie's Avatar
Default 91 usdm crx SI cluster in 90 civic DX ?????
Im sure this has been covered a million times, but i searched the hell out of it so here goes. Does a 91 crx SI cluster just "WORK" IN A 90 DX. I thought it did. But when i plugged it into my dx, the tach wouldnt work, and i got some funny warning lights. I am very proficient with wiring so Im sure i can figure it out if need be. I just want to know if it is supposed to work. It just seems that it would. Thanks all
Old Mar 10, 2005 | 06:15 PM
HatchBox's Avatar
Skoobie no more...
Default Re: 91 usdm crx SI cluster in 90 civic DX ????? (turboartie)
your sure that you got a 90 cluster? Not a 88-89
Old Mar 10, 2005 | 06:20 PM
EP3_05's Avatar
It should be plug and play. I used a 90 si cluster in my 91 dx sedan and all I did was remove the old cluster and installed the new one. Like hatchbox said you may have an 88-89 cluster.
Old Mar 10, 2005 | 06:24 PM
GreenBean's Avatar
Default Re: 91 usdm crx SI cluster in 90 civic DX ????? (91civic)
The clusters from 90-91, have a slightly domed top...
Especially when compared to the 88-89 clusters that have an absolutely straight top,
And also the wiring is very different, as you might already know...
Old Mar 10, 2005 | 06:29 PM
HatchBox's Avatar
Skoobie no more...
Default Re: 91 usdm crx SI cluster in 90 civic DX ????? (GreenBean)
also
Look for the word DENSO or a littel NS symbol.
Denso = 88-89
NS = 90-91
Old Mar 10, 2005 | 06:30 PM
GreenBean's Avatar
I got these off of e-bay....lol...
88-89, see the absolutely flat top and the turn signal lights are by themselves on the left and right of the center section.
90-91 have a rounded top edge, and also you can see the high beam indicator is next to the left turn signal and the right turn signal has an indicator next to it but I can't make it out.
Old Mar 10, 2005 | 06:37 PM
DieMaster's Avatar
Needs to be About 20% Cooler
there is no light on the right indacator. it's a blank. (future home of my vtec light )
Old Mar 11, 2005 | 02:22 AM
GreenBean's Avatar
Default Re: 91 usdm crx SI cluster in 90 civic DX ????? (DieMaster)
Cool, I didn't know...
But I will soon, just won my cluster on e-bay last night...hehehe...for my 91-DX
Will be in soon
Old Mar 11, 2005 | 03:20 PM
turboartie's Avatar
Right on guys. I just noticed I have an early cluster. DUH Sorry, i have a lot of honda parts laying around and i thought it was a newer cluster. I checked again and the bolt holes dont even line up. Thanks guys
crazy bum
13
Mar 28, 2010 06:04 AM
coffin on wheels
Feb 20, 2007 06:24 PM
inspecta83
Oct 18, 2003 08:38 AM
element_1one
Jun 3, 2003 09:08 AM
swtcivic93
Mar 1, 2002 09:56 AM
