swaped crx not getting up to temp HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 10, 2005 | 06:00 PM
88cerx's Avatar
Default swaped crx not getting up to temp HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ok did the swap new water pump, radiator,coolant lines 180 stat. checked everything but cant find the remedy the lower hose is always cold if i drive the car but if i let it sit for 30 min then it gets up 2 Temp. then if i drive it hard it stays warm if i chill then the temp drops to about 1/3........? the if i just drive the car it goes to about 1/3 and if i bring it to 5500 rpm or higher the temp drops to cold wtf??????????????? not to mention its 30F outside but that still shouldn't matter..should it????
Old Mar 10, 2005 | 06:39 PM
acuratech's Avatar
Default Re: swaped crx not getting up to temp HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (88cerx)
I have seen this often at work, in accords, civics etc... Thermostat has always done it for me. Does your engine have a coolant bleed valve? Did you go with an oem thermostat?
Old Mar 10, 2005 | 06:46 PM
drdisco69's Avatar
Default Re: swaped crx not getting up to temp HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (acuratech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuratech &raquo;</TD></TR><TR><TD CLASS="quote">Does your engine have a coolant bleed valve? Did you go with an oem thermostat?</TD></TR></TABLE>
Old Mar 10, 2005 | 07:29 PM
88cerx's Avatar
Default Re: swaped crx not getting up to temp HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (drdisco69)
the stat is brand new 180 degree, and it is working (lower hose is cold untill it warms up ideling) as for the bleeder i don't know because it had a hose connected to the front of the head to the fitv valve but cut it today and pluged it and seemed to let it warm up better but if i chill it still goes cold
Old Mar 10, 2005 | 09:10 PM
88cerx's Avatar
bump
Old Mar 10, 2005 | 09:33 PM
hahagasdcrx's Avatar
sounds like the thermostat is stuck open, or installed wrong( somehow ).
Old Mar 10, 2005 | 10:03 PM
88cerx's Avatar
Default Re: swaped crx not getting up to temp HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (hahagasdcrx)
no it installed properly and its working but still gets cold
Old Mar 11, 2005 | 08:12 AM
88cerx's Avatar
Old Mar 11, 2005 | 11:07 AM
88cerx's Avatar
just put in a new stat to see if remidy the problem w/ same result still wont get hot unless i sit there at 2000 rpm not moving. please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 11, 2005 | 01:40 PM
ssl2k's Avatar
put some cardboard infront of the radiator.
Old Mar 11, 2005 | 01:43 PM
limpy's Avatar
Default Re: (ssl2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88cerx &raquo;</TD></TR><TR><TD CLASS="quote">the stat is brand new 180 degree, and it is working (lower hose is cold untill it warms up ideling) as for the bleeder i don't know because it had a hose connected to the front of the head to the fitv valve but cut it today and pluged it and seemed to let it warm up better but if i chill it still goes cold </TD></TR></TABLE>
i had the same problem... replace the thermostat, and it should work fine just do it it is only 5-10 bucks and it will fix your problem
Old Mar 11, 2005 | 01:53 PM
n8barton's Avatar
i belive that integ uses a 195 temp thermost. anyway, doesnt it?
Old Mar 11, 2005 | 02:37 PM
88cerx's Avatar
Default Re: swaped crx not getting up to temp HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (n8barton)
no seriously i did all of that im on my 3rd stat alredy put cardboard in front of rad and everything this is not cool the stat seems to work till i get over 5000 rpms WTF does anyone have a coolant line diagram for the 94 ls motor???? i seriously have been stumped on this there is nothimg out of place accept the bleader line that i cut and plugged but i still shouldn't have to do that WTF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! i know someone here has had this prob please please please HELP!!!!!!!!!!!!!
Old Mar 12, 2005 | 05:21 AM
88cerx's Avatar
morning bump still need info
Old Mar 12, 2005 | 09:00 PM
88cerx's Avatar
Joshable14
Jul 20, 2015 10:10 AM
all-mtr-teg
Jul 13, 2008 04:22 PM
WhiteOnRice
11
Nov 30, 2007 12:59 PM
soon2bdropped
Apr 6, 2007 11:34 AM
allmotor.net
Apr 24, 2003 02:58 AM
