Honda S2000 Honda S2000
AP2 headlight swap
Old Mar 10, 2005 | 05:25 PM
glass3ater's Avatar
Default AP2 headlight swap
Performed a search and actually couldn't find anything... sure it's been covered though.
What type of modification is needed to swap the 04+ headlights into an 01' ?
Different bulb harnesses? I'm probably going to swap mine out because my passenger's side headlight housing is pretty fogged up and I'd almost rather just go with the ap2 lights while I'm at it.
Has anyone on here swapped them out? And if so, is it worth it or should i just buy another ap1 headlight housing and call it a day?
Old Mar 10, 2005 | 05:35 PM
fknfast's Avatar
Default Re: AP2 headlight swap (glass3ater)
http://www.hardtopguy.com
we sell hundreds of these!!
Francesco's Avatar
you have to do some modification to the wiring harness and get the smaller ballasts so that the headlights will fit. you can use ap1 ballasts, but you need to modify them so that they fit the ap2 lights.
Old Mar 10, 2005 | 05:45 PM
glass3ater's Avatar
Default Re: AP2 headlight swap (Francesco)
thanks. How tough are the mods to the ballasts/harnesses?
Old Mar 10, 2005 | 06:24 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">you have to do some modification to the wiring harness and get the smaller ballasts so that the headlights will fit. you can use ap1 ballasts, but you need to modify them so that they fit the ap2 lights.</TD></TR></TABLE>
daym... frank knows his lights hehehehe
Old Mar 10, 2005 | 07:40 PM
Nishant's Avatar
Default Re: AP2 headlight swap (03s2kblue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">
daym... frank knows his lights hehehehe</TD></TR></TABLE>
its been covered so many times on s2ki
Old Mar 10, 2005 | 07:44 PM
papa5murf's Avatar
Default Re: AP2 headlight swap (Nishant)
hahahah true
Old Mar 10, 2005 | 07:45 PM
Nishant's Avatar
plus he looked into it himself when he replaced his front bumper
Old Mar 10, 2005 | 07:48 PM
Francesco's Avatar
yup, i wanted the ap2 lights when i did my front. i decided not to though because i didnt want to play with the wiring harness and cut into them. plus the ap1 lights look much better
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">yup, i wanted the ap2 lights when i did my front. i decided not to though because i didnt want to play with the wiring harness and cut into them. plus the ap1 lights look much better </TD></TR></TABLE>
don't you have to move a reservoir or something too?
Old Mar 10, 2005 | 07:54 PM
Francesco's Avatar
not that i know of
Old Mar 10, 2005 | 08:02 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">not that i know of</TD></TR></TABLE>
or is it just the ballast?
Old Mar 10, 2005 | 08:06 PM
Francesco's Avatar
just the ballast. you have to use the 04's...but if your doing the swap, you can just modify the ap1 ballast to work. i think the ap1 ones are smaller. i can't remember though...
Old Mar 10, 2005 | 08:08 PM
glass3ater's Avatar
it's all good, I'm just going to stick with the AP1 lights.. there's nothing wrong with them.. just wanted to try something different but blah.. too much money
Old Mar 10, 2005 | 08:13 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by glass3ater &raquo;</TD></TR><TR><TD CLASS="quote">it's all good, I'm just going to stick with the AP1 lights.. there's nothing wrong with them.. just wanted to try something different but blah.. too much money</TD></TR></TABLE>
yeah those ******* are expensize...try ebay though, you can snag a pair for 400$ i think. arnt they 850$ a piece from Honda?
Old Mar 10, 2005 | 08:14 PM
Nishant's Avatar
the ap2's go for 600-800
glass3ater's Avatar
the ballasts at honda are like $500 and the bulbs themselves are $200-$210 depending on which dealership you go to
Old Mar 10, 2005 | 08:16 PM
Nishant's Avatar
http://www.hardtopguy.com jeff is always cheaper
pnjbiboye
Jul 17, 2007 03:12 PM
lsvtek
Nov 12, 2006 05:20 AM
93h22hatch
Jul 19, 2006 06:21 PM
J4k3
Apr 6, 2006 05:35 PM
spoolude
Apr 10, 2005 08:08 PM
