Destroyed my stock LS block
Old Mar 10, 2005 | 04:33 PM
dragsol's Avatar
Default Destroyed my stock LS block
I ran a 12.05 @ 115 W/11lbs. and 50 shot of nitrous. then I tryed to turn it up to get around a 11.7 but here is the aftermath of that pass. We have been 11.4 @128 with a stock LS motor but something wasnt working right with this tune up.
Here is a pic of the car. I was running 24.5" slicks on the passes
The piston that you see in the left cylinder is just the top of the piston. Below it is no evidence of a rod.
Modified by dragsol at 3:06 AM 3/11/2005
Old Mar 10, 2005 | 04:40 PM
lucky one's Avatar
Default Re: Destroyed my stock LS block (dragsol)
Looks good next time try speedshifting.
Old Mar 10, 2005 | 05:16 PM
SpeedDreamz.com's Avatar
Default Re: Destroyed my stock LS block (lucky one)
Are you surprised?
Old Mar 10, 2005 | 05:35 PM
mtber's Avatar
Default Re: Destroyed my stock LS block (SpeedDreamz.com)
What kind of whp were you making ?
What did you use to tune your setup if anything ?
Who tuned it ?
Just curious...
Old Mar 10, 2005 | 05:37 PM
JL's Avatar
JL
disgusting.
Old Mar 10, 2005 | 05:57 PM
nsxmatt's Avatar
I only read the stock block and 11lbs and wondered what went wrong then I read the 50 shot on top. Gotta kind of expect it then. Sorry to hear about it though..
Old Mar 10, 2005 | 06:00 PM
dragsol's Avatar
I used a FJO wideband and street tuned. I have also ran 11.1 @ 129 with out vtec activating on a b17 in a different car with different set up. Yes I was suprised to see the motor die so soon. I have been much faster with other ls's and they would last for seasons at a time not just glory passes. I didnt just run 11.5 with one stock Ls motor.
Old Mar 10, 2005 | 07:20 PM
Jockobo's Avatar
that sucks...i juss blew mine recently too...got any ideas of what went wrong ?
Old Mar 10, 2005 | 07:36 PM
Squirtle's Avatar
That sucks! What kind of injectors and what were you shifting at?
Old Mar 10, 2005 | 07:46 PM
2k.civic.si's Avatar
Default Re: Destroyed my stock LS block (Jockobo)
let me take a wild guess....judging by the size of that turbo....when you turned up the boost...your charge temp went up....increased air temp = boom....heck im bored....maybe you forgot to retard the timing more when you turned up the boost? what kinda management u running?
Old Mar 10, 2005 | 08:49 PM
sporkcrx's Avatar
What kind of tires on the front in that pic? Usual 60's? Badass rex
Old Mar 11, 2005 | 10:06 AM
Suprdave's Avatar
Damn, yu guys have alot of fricken cars.
Old Mar 11, 2005 | 11:09 AM
4piston's Avatar
Default Re: Destroyed my stock LS block (Suprdave)
Dave...those are the guys that bought our gold car. Nice rex
Old Mar 11, 2005 | 12:29 PM
Stewie's Avatar
Default Re: Destroyed my stock LS block (4piston)
nice times for what would have been a stock motor
Old Mar 11, 2005 | 01:19 PM
91' LS-VTEC's Avatar
Default Re: Destroyed my stock LS block (Stewie)
carnage
Old Mar 11, 2005 | 03:03 PM
dragsol's Avatar
Default Re: Destroyed my stock LS block (91' LS-VTEC)
I had the rev limiter set at 7700 rpm. I am running 720cc injectors, zdyne gold. I was pulling .75 degrees of timing per pound starting at 5 pounds. We got the car going again but I will keep the rev limiter to around 7200 rpm. I was running 7700 rpm because I had good size all motor crane cams and JG intake manifold so it was making all of its power on the top end. the tires in the pic are 225-50-15 BFG drag radials. I was cutting 1.84 60fts. It has an open diff, and stock struts and stock springs on the front, skunk 2 street struts on the rear. Just dumping to clutch on the spray at about 6500 rpm. Not the best way to do it but I was satisfied since it was opening day at the track.
Old Mar 11, 2005 | 04:25 PM
Tupoint4's Avatar
ouch
Old Mar 11, 2005 | 04:34 PM
hondaguyef's Avatar
Default Re: Destroyed my stock LS block (Tupoint4)
For the quick *** car(s) and the stock LS. **** happens sometimes! Get another LS longblock and get back to the track
Phil
Old Mar 12, 2005 | 05:23 AM
NO PRESSURE's Avatar
Default Re: Destroyed my stock LS block (hondaguyef)
Did u had any Internal done to it ????
Old Mar 12, 2005 | 01:15 PM
Tomek's Avatar
Default Re: Destroyed my stock LS block (NO PRESSURE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NO PRESSURE &raquo;</TD></TR><TR><TD CLASS="quote">Did u had any Internal done to it ????</TD></TR></TABLE>
reading comprehension owns you
Old Mar 12, 2005 | 03:00 PM
TurboCX's Avatar
Default Re: Destroyed my stock LS block (Tomek)
Does your brother still have that red CRX. I remember racing him a few times at Battle in Joliet. I also remember that he told me had a stock LS as well.
Old Mar 12, 2005 | 03:56 PM
BoostedCivicSedan's Avatar
Default Re: Destroyed my stock LS block (TurboCX)
Damn, you beat me... Mine was nowhere near that bad....
Old Mar 12, 2005 | 07:45 PM
dragsol's Avatar
He still has the car. It is now white. You wouldnt recognize it from the transformation it has been through. He was running a stock Ls.
Here is a pic of it
Old Mar 14, 2005 | 10:40 PM
RockinSOHC's Avatar
time to build a new motor man. good times on the stock LS block
dahoopdahup
Mar 5, 2006 09:53 PM
dragsol
Apr 23, 2003 07:44 PM
dragsol
Oct 27, 2002 03:56 PM
DLB1994
Jun 10, 2002 08:02 PM
