Questions about B20 Swap setup, Parts etc..
Old Mar 10, 2005 | 03:39 PM
JMod's Avatar
Default Questions about B20 Swap setup, Parts etc..
I'm running a stock b20b bottom end with a gsr head w/ stock gsr cams. I'm going to be running an obd2-obd1 conversion harness. I need some suggestions and some help. This is in a 96' Hatch btw. 1st off, can I reuse my distributor off the single cam? Can I use the stock b20b injectors? And can the sohc alternator be used as well?
The only parts I need now is a tranny with clutch/flywheel, and the motor mounts. I have the shift linkage and everything else. Sound like i'm missin anything?
EGhatch33
Mar 15, 2007 10:29 PM
Spec R
Jul 29, 2005 09:07 PM
JMod
Mar 10, 2005 06:03 PM
relic_sypher
Feb 19, 2002 12:41 PM
