OBD2 -> OBD1 ECU; wiring harness + kick panel?
Old Mar 10, 2005 | 09:54 AM
Aracheon's Avatar
Default OBD2 -> OBD1 ECU; wiring harness + kick panel?
Alright, so I just bought a P75 OBD1 ECU from a 95 Integra and put it into my 99 LS. The problem I'm having, however, is that the OBD2 -> OBD1 wiring harness has so much plastic and extra wire to it that I can't put the kick panel back on. Hell, I can't even get that goldish colored metal plate to bolt onto it. Does anyone have any suggestions as to how to clean this up? How about someone who's done this swap, take pictures of what they did?
Right now, I've got an ECU and wiring hanging out on the floor. >.<
Old Mar 10, 2005 | 01:02 PM
virusiidx's Avatar
just stuff it in ghetto style y0
I just stuffed my harness in there and made it fit, some will just hide it under the carpet , etc...
I'm sure you'll figure it out.
Old Mar 10, 2005 | 02:03 PM
iH8RICERZ's Avatar
Default Re: (virusiidx)
theres been a few threads about this as well.....some people have bent the wires for the harness and shoved the ecu back in its original place and had no problems. Other people lift up the carpet and place it under there, and othe rpeople have some how re-routed the ecu into the glove box..dont ask me how
Old Mar 10, 2005 | 02:33 PM
1Quikgsr's Avatar
i just bent the wires and worked for me
Old Mar 10, 2005 | 02:46 PM
92TypeR's Avatar
FSAE
Default Re: (1Quikgsr)
Take off the plastic loom that the wires go through so you can bend them.
You will not be able to use the metal tray.
I was able to bolt my P72 down and put the plastic kickpanel back on, but the rear plastic bolt no longer fits, so its a little more loose than before.
Old Mar 10, 2005 | 02:53 PM
IVI's Avatar
IVI
Default Re: (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">Take off the plastic loom that the wires go through so you can bend them.
I was able to bolt my P72 down and put the plastic kickpanel back on, but the rear plastic bolt no longer fits, so its a little more loose than before.</TD></TR></TABLE>
that pretty much summed it up.
Old Mar 10, 2005 | 03:15 PM
T3mp3sT's Avatar
yup.
Or be ghetto like me and put it in your glove box rofl!
Old Mar 10, 2005 | 05:11 PM
smkngsr's Avatar
Default Re: (T3mp3sT)
i kinda force mine in there but carefully done it because im affraid that the harness socket might come out...just take time and carefully force them there...mine fits perfect like nothing happens with my vafc harness...theres always way around
Old Mar 11, 2005 | 07:19 AM
Aracheon's Avatar
I didn't know if there was some kind of trick to it. I appreciate the replies, everyone. Thank you! I'll give that a shot tonight.
yungkhmer
Jan 7, 2014 05:51 AM
JustAskMe
Aug 19, 2010 10:47 AM
-Todd-
Feb 5, 2006 03:58 PM
DGAF
Jul 7, 2005 05:37 AM
i3oricua
May 24, 2003 12:20 AM
