JDM EG8 Civic Ferio D15B VTEC Honda Part Numbers
Someone suggested I post this on honda-tech, too... so here it is...
(btw, it was useless in the EG forum... i guess it applies to all models)
From d-series.org:
Yes, I have the hookup on any part number in the EG8 D15b vtec. (or any d-series JDM sedan). I will be listing all the important part numbers with comments where appropriate to dispel all the garbage info that people have made up or gotten from other people.
If anyone tries to order the JDM parts at a dealer, please post your experience. It would be nice to find out how to get these.
BLOCK SECTION
Block:11000-P07-800 <--- slightly different than VX
Piston set: 13010-P08-010 <--- unique to d15b vtec
oversize 0.25: 13020-P08-010
oversize 0.50: 13030-P08-010
Ring set : 13011-P08-004
Connecting rod set: 13210-PM6-000
Crankshaft:13310-P08-000 <--- completely unique
Connecting rod bearing A: 13211-PE0-003
HEAD SECTION
head assembly: 12100-P08-010 <---almost same as z6
camshaft: 14110-P07-000 <---unique! big surprise
cam pulley:14210-PM3-000 <--- same as VX
intake valves: 14711-P08-000 <--- unique
(also 14711-p2A-000)
exhaust valves: 14721-P08-000 <--- unique
(also 14721-p2A-000)
intake v. spring: 14761-P08-003 <--- unique
exhaust v. spring:14762-P08-003 <--- unique
valve seats/retainers: same as VX
Suspension
Front springs: 51401-SR3-K01 <- seems these are the same as on the EX sedan
AND 51401-SR3-K02 - but there are two brands: Showa and Mibishi
OTHER
stock LSD unit: 41200-P20-L23
intake manifold: 17100-P08-J00 <--- practically same as z6, but missing one screw hole for purge solenoid, hence barely different part number
What else do you want?
Modified by makku at 10:48 AM 3/10/2005
From d-series.org:
BLOCK SECTION
HEAD SECTION
Suspension
OTHER
Have access to the Vtec B15 .. Would like to put it in a Civic SI 1.6 with B16 now...would everything hook up ? And I suppose you would have to change the wiring harness plus the ECU.. Correct ? Or what else would have to be done to change it out...
Thanks
N
Advance
Thanks
N
Advance
2000 Si? engine will fit, BUT b16 transmission will not fit on d15b, ecu will not work, harness won't work.
dude, there's a forum specifically for swapping engines. this post is for identifying engine parts... to do a rebuild or whatever.
makku
Mar 16, 2005 05:11 PM
