h22a eg's using HASport mounting kit. What rear engine bracket are you running?
Old Mar 10, 2005 | 08:53 AM
patastinky's Avatar
Default h22a eg's using HASport mounting kit. What rear engine bracket are you running?
I read the sticky and have spoken w/ alot of ppls about this. Everyone says to use 92-96 Rear prelude engine bracket because the 97+ are different.
The HASport instructions that come w/ the kit say that you can use a 92+ Rear engine bracket no problem. I also emailed HASport and brought up this question and they replied that " yes i can use a 97 prelude rear engine bracket ".
So. . Is anyone running a 97+ rear prelude engine bracket? Has anyone tried to use one? ..
I am sure this will/should clear up alot of speculation.
Btw, the 97+ AUTO and MANUAL rear engine brackets are the SAME They look the same.. excatly the same. And they have the same part number
Below is a picture of a 97+ auto/manual prelude rear engine bracket #7
Below is a picture of a 92-96 Manual prelude rear engine bracket #9
Old Mar 10, 2005 | 07:19 PM
patastinky's Avatar
Default Re: h22a eg's using HASport mounting kit. What rear engine bracket are you running? (patastinky)
Anyone? I would havet thought that this thread would have gotten some replies by now
Old Mar 11, 2005 | 06:09 AM
Ministry's Avatar
I'm currently using the bracket from my wrecked 2000 prelude. it's been fine for the past 2 years or so.
Old Mar 11, 2005 | 07:10 AM
patastinky's Avatar
Default Re: h22a eg's using HASport mounting kit. What rear engine bracket are you running? (dreamer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreamer &raquo;</TD></TR><TR><TD CLASS="quote">I'm currently using the bracket from my wrecked 2000 prelude. it's been fine for the past 2 years or so.</TD></TR></TABLE>
You have an eg and are running either.. egh1 or egh2 correct?
Old Mar 20, 2005 | 10:40 AM
tougeEGsies's Avatar
i had the same problem, i found a 92 prelude bracket a a local yard though.
I dont know about 97+ bracket they look the samee in the picture, and these companies are cheap they use the same parts on as many cars as posible, they might be the same.
I know the rear bracket out of the 92 accord 5 speed is the same. i got one of those from my buddy.
bump
Old Mar 20, 2005 | 11:33 AM
SixguN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patastinky &raquo;</TD></TR><TR><TD CLASS="quote">I read the sticky and have spoken w/ alot of ppls about this. Everyone says to use 92-96 Rear prelude engine bracket because the 97+ are different.
I just went through this with another guy on here. You need the 92-96 mounting bracket. They are different.
Old Mar 21, 2005 | 07:54 AM
Ministry's Avatar
Default Re: h22a eg's using HASport mounting kit. What rear engine bracket are you running? (Sixgundone)
hmm. my setup works just fine with the 2000 rear bracket. am I missing something? is my car just special? Don't Brian and the guys at Hasport say its ok too?
Old Mar 21, 2005 | 07:50 PM
SixguN's Avatar
Your the guy I just went through this with, right? I thought you siad I need a 92-96 rear bracket. And thats what I did. And now it works fine. Cause I couldnt get the 97+ bracket to line up. Is this a 97+ h22? If not. My bad. Didn't mean to cause confusion.
Old Mar 21, 2005 | 08:00 PM
patastinky's Avatar
I got him a 92-96 prelude bracket. I said **** it to all the b.S. .. hmmm i might be the guy. The swap is not for me, its for my friend in OHIO that is doing the swap. He asked me if i knew if there was differncnce so i thought i'd search and ask. Seems like there is alttle bit of a differnce..
So to end this all .. Just go get yourself a 92-96 rear prelude bracket and call it a day!!
Old Mar 21, 2005 | 08:53 PM
SixguN's Avatar
I meant dreamer was the guy I went through this with. He explained to me no too long ago that I needed a 92-96 bracket. sry for the mix up.
blue_dlb
Jun 3, 2009 12:49 PM
ryanevansoh
Jan 24, 2009 01:18 AM
hybridpatient95
Jan 20, 2006 03:22 AM
