90 civic si w/B16a1, not getting any spark
Well to start off the car has been running a little rough since i just picked it up, but it felt like bad gas from the car sitting for 6 months. Therefore i filled up with 93octane and let it run for about a half hour and then it started to sound like it was missing. So i pulled the plugs and they looked like i was actually running a little lean, so i replaced them. It then just died at a stop sign and i had to push it to my friends house (really fun). After trying to start it some more i pulled the plugs and there was plenty of fuel getting in but i then tested the plugs and wasnt getting any kind of spark.
So i took the cap of the dizzy and it looked a little white inside of it and smelled like it was burning a little bit. Now how can i tell if its bad or how can i clean it and try it again? Or could it be someting else?
(the car is a 90 civic si with a B16 OBD-0)
Bump....
the dizzy on the car looks to be fried, its also stamped as TC-05A, i dont even know what car that came off of but i thought that the Dizzy for the b16a1 obd-0 should be TD-22U
someone help me out here....
I've read at a couple different places that a Teg distributor will work but you have to knock one of the legs off but I put "TC-05A" in Google and it came back with a CRX?
Good place for a replacement is Distributor King: http://stores.ebay.com/DISTRIB...QtZkm
Fast, reliable, and a 3 year warranty...cap, rotor, igniter...everything!
Here's a list of USDM distributors with numbers, see page 2... http://www.rbinc.com/pdfs/2300...t.pdf
TC-05A distributor in a b16a... interesting
fyi, you can find them alittle cheaper at Distributor King, $159 with free shipping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedracer228 »</TD></TR><TR><TD CLASS="quote">so that came off of the awd civic wagon? no wonder it fried. I wonder what douchebag put it on this motor...
LMAO! sorry the douchebag part got me
</TD></TR></TABLE>LMAO! sorry the douchebag part got me
BUMP
still no spark....
so far ive put in new plugs, brand new dizzy from streetimports.com, checked the ecu (no codes and opened it up), fuel pump turns on(main relay is good), checked wiring and still nothing. Any suggestions would be appreciated.
still no spark....
welp problem solved....
the teeth of the new dizzy broke off in the camshaft!!
switched the broken peice with the one from my old dizzy and fired right up.
greatxpectations
Jan 22, 2006 09:31 PM
