B18C5 in EK coupe
Just a quick question in regards to my visit to the local test and tune session. My friend owns a 97' Civic DX coupe with a USDM type R I/H/E. He managed a 13.97 @ 97mph with a 2.18 60'. Is this unusually slow for a C5 swap in a coupe or is it typical? The E.T. seems in tune with the mph on street tires so some feed back involving others with C5 swaps would be helpful. Thanx.
Sam
Sam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ea_hatch »</TD></TR><TR><TD CLASS="quote">sounds like a pretty good time to me</TD></TR></TABLE>
Thank you. I drove relatively aggressive to aquire that E.T. although the 60' was dismal on drag radials. I just thought it should be quicker with that swap and wanted to see what other people are going. Although my friend going 14.00's with the identical swap in a lighter CX hatch was encouraging.
Sam
Sam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFoutkast »</TD></TR><TR><TD CLASS="quote">how many runs did he do? I think with a few more trys i could shave down that E/T a bit.. just my .02
He made several back to back 14.20 passes and I managed to nail a 13.97 on my first trial pass. I'm thinking if I would've had the opportunity to try a couple more times, I may have gotten down to the 13.70 range with 2.0 60's.
Sam
</TD></TR></TABLE>He made several back to back 14.20 passes and I managed to nail a 13.97 on my first trial pass. I'm thinking if I would've had the opportunity to try a couple more times, I may have gotten down to the 13.70 range with 2.0 60's.
Sam
Thanx for all the kind and encouraging words guys. However I'm still weary to why it only ran high 13's. I've heard of Type-R swaps going mid 13's at 100-101mph on street radials. Whoever has the same swap with similiar mods, please shed some light. Thanx.
Sam
Sam
i think thats a pretty good time for a usdm motor. one of my buddy's had a 00SI coupe with a jdm R motor and i believe his best on drag radials was around 13.5xx to 13.6xx. did you run open header or full exhaust? you prolly would've hit a lower e.t. if you had more seat time since you said your first pass was the 13.97......you know the saying "practice makes perfect"........any pics of the car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92Jspec »</TD></TR><TR><TD CLASS="quote">i think thats a pretty good time for a usdm motor. one of my buddy's had a 00SI coupe with a jdm R motor and i believe his best on drag radials was around 13.5xx to 13.6xx. did you run open header or full exhaust? you prolly would've hit a lower e.t. if you had more seat time since you said your first pass was the 13.97......you know the saying "practice makes perfect"........any pics of the car?</TD></TR></TABLE>
Nah, no pics I'm afraid. Just a plain jane silver DX coupe on old fat fives. It was ran on full exhaust shod on 205 G-forces. Do you recall his mph on either the 13.5 or 13.6 pass? I figure the mph should tell the difference in horsepower.
Sam
Sam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si »</TD></TR><TR><TD CLASS="quote">i ran a 14.0@99 2.23 60 with b18c block/b16head/ctr 81.5mm pistons/itr cams im my somewhat striped out 2k si on 17inch nitto's</TD></TR></TABLE>
Good mph. I wish I would've had the opppprtunity to run on slicks. I had a set of 22x8x13's sitting in the trunk but I was too lazy (and cold) to bolt them on.
i have m&h 22's on bogart 13x8's....problem is i need extended wheel studs put on to run them.....and i cant get that big nut off to pull the hub to do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si »</TD></TR><TR><TD CLASS="quote">i have m&h 22's on bogart 13x8's....problem is i need extended wheel studs put on to run them.....and i cant get that big nut off to pull the hub to do it
Strange, I had those slicks mounted on my 99' EK coupe, stock studs no problem. Had some different lugs though. I wonder if that made a difference.
</TD></TR></TABLE>Strange, I had those slicks mounted on my 99' EK coupe, stock studs no problem. Had some different lugs though. I wonder if that made a difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceProfessor »</TD></TR><TR><TD CLASS="quote">
Sam</TD></TR></TABLE>
nah i don't remember the exact mph that was about 2 yrs ago. the only diff. is the usdm has 190-195(i think) and the jdm has 200. the diff. between the two is the final drive and the compression on the jdm it has a 4.7 final drive and 11.0:1 and the usdm has a 4.4 and 10.8:1......either way i bet that badboy is fun as hell to drive. i am currently working on a bswap and can't wait to finish.......
Strange, I had those slicks mounted on my 99' EK coupe, stock studs no problem. Had some different lugs though. I wonder if that made a difference.</TD></TR></TABLE>
your like the zillionth person to tell me this....im now in search of longer lugs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceProfessor »</TD></TR><TR><TD CLASS="quote">Just a quick question in regards to my visit to the local test and tune session. My friend owns a 97' Civic DX coupe with a USDM type R I/H/E. He managed a 13.97 @ 97mph with a 2.18 60'. Is this unusually slow for a C5 swap in a coupe or is it typical? The E.T. seems in tune with the mph on street tires so some feed back involving others with C5 swaps would be helpful. Thanx.
just thinking about this....if this is still on stock ecu...he's moving
your like the zillionth person to tell me this....im now in search of longer lugs</TD></TR></TABLE>
you have a 00 Si correct? the si's have bigger calipers thats why you need the longer studs and spacers, so they will clear them. i ran into the same prob.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99skunkedSi »</TD></TR><TR><TD CLASS="quote">
you have a 00 Si correct? the si's have bigger calipers thats why you need the longer studs and spacers, so they will clear them. i ran into the same prob.</TD></TR></TABLE>
yes i have to run spacers
phan321
Aug 3, 2006 06:47 PM
