2000 accord - need timing belt?
Old Mar 10, 2005 | 07:10 AM
m2k's Avatar
m2k
Default 2000 accord - need timing belt?
just bought a 2000 accord lx with 85000 miles from a large car dealer in my area and it came with a 1 month warranty. I took it to my honda mechanic AFTER I bought it (mistake) and they said the timing belt should have been replaced by now and that the transmission fluid was dirty. I'm taking it back to the dealer to discuss the mechanic's report today. My questions: Are there signs to look for that indicate you need a new timing belt? How much is it, and should I push for them to replace it? The car seems to run fine to me. Also, they said the front brake pads were under 25% and that the rotors were overheating. I assume this will be taken care of. Thanks.
Old Mar 10, 2005 | 07:22 AM
BuCxLuXoRX2o0o's Avatar
Default Re: 2000 accord - need timing belt? (m2k)
i think it recommend to change at 105K miles.
Old Mar 10, 2005 | 08:04 AM
jweller's Avatar
there are few signs of a worn out timing belt. If you can see a probalem with the belt, it is going to break very soon. If it breaks you are looking at an expensive repair. expect the replacement to cost $300 or more at a dealer. Yes I would push for it to be replaced.
as for the brakes, or anything else, never assume they will be taken care of. 25% is probably right at the service limit, and so there is theoreticly "nothing wrong" as it will pass inspection just fine.
Old Mar 10, 2005 | 01:28 PM
Turbowa's Avatar
Default Re: 2000 accord - need timing belt? (jweller)
As stated earlier the interval is 105k on the timing belt. There is no real way to inspect it that is why its recommended to be repalced at a certain milage.
As for the brakes, close but no cigar jweller the service limit on the front brakes is 2mm till indicator. Translation 20% left the pads start out roughly at 10mm new. As for the rear the service limit is 1.6mm or still 20% the rear pads are only 8mm new.
Depending on how you drive and if its mainly city or freeway you could see any were from 3-8k miles out of the front brake pads before they need replaced. And if I were you with them being hot spoted if they are that bad I would replace the rotors too with the brake pads. Simple machining them won't cut it. (no punp intended)
Old Mar 10, 2005 | 06:34 PM
goowakjai
Guest
Posts: n/a
my timing belt had to be replaced sumwhere near 80K so if the previous woner didnt replace it yet, then yea, its probably time
Old Mar 10, 2005 | 07:07 PM
shawn_crx's Avatar
Default Re: 2000 accord - need timing belt? (goowakjai)
the dealer over here said it's about 90k
Old Mar 10, 2005 | 07:37 PM
Tennessee Lich's Avatar
Default Re: 2000 accord - need timing belt? (shawn_crx)
BEWARE LADIES AND GENTLEMEN!!!!!!!!!!!!!!
As of recent my water pump has needing replaced FINALY at 145K miles . So naturaly and smatly you replace Both timeing belts. STOCK HONDA BELT > TIMEING BELT ALPHA !!!!!! Out of Hoda Dealerships have been makeing the belt OVER SIZED!!!!!!!!!!!!!!!!.. Yes OVERSIZED. The balancer wonteven catch the belt in the motor . Sugestion go with GOODYEAR Belts replacememnt. Due to they have the right size of belt and avoid the slapping and mis linkage in near future of this HONDA defect...
Lisrten to me or not .... Just check it out if your doing it and be smart ...
Old Mar 10, 2005 | 08:33 PM
goowakjai
Guest
Posts: n/a
Default Re: 2000 accord - need timing belt? (Tennessee Lich)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tennessee Lich &raquo;</TD></TR><TR><TD CLASS="quote">BEWARE LADIES AND GENTLEMEN!!!!!!!!!!!!!!
As of recent my water pump has needing replaced FINALY at 145K miles . So naturaly and smatly you replace Both timeing belts. STOCK HONDA BELT &gt; TIMEING BELT ALPHA !!!!!! Out of Hoda Dealerships have been makeing the belt OVER SIZED!!!!!!!!!!!!!!!!.. Yes OVERSIZED. The balancer wonteven catch the belt in the motor . Sugestion go with GOODYEAR Belts replacememnt. Due to they have the right size of belt and avoid the slapping and mis linkage in near future of this HONDA defect...
Lisrten to me or not .... Just check it out if your doing it and be smart ...</TD></TR></TABLE>
huh? say wut now? it sounds like u have sumthing knowlegable to say, but i cant understand -_-a
Old Mar 11, 2005 | 04:37 AM
Turbowa's Avatar
WHAT, you must be smoking crack or work for goodyear. The factory belts whan installed PROPERLY will fit every time perfectly. ALL of hondas belts not just the timing belts are designed and made buy Gates Rubber. They have been for over 20 years. Hell they even designed the timing belt drive system on teh 98-02 accords for honda to avoid the blowing out front balancer shaft oil seal. Remember the re-call. I would never trust a goodyear belt on my lawn mower let alone my car. How can I be so certain you say, easy My dad works for the Gates Rubber Company and has for over 23 years. And just to clearify Bando, Mitsuba, Gates all the same company just come from different parts of the world. Besides that the belts that gates provides come out of a factory jointly owend between Honda and Gates and it has to meet hondas requierment before it can even leave. This why its better then just going to your local napa store and buying a belt that is still made by gates but costs less, its not the same construction.
Dfullmer
Jul 13, 2017 08:27 AM
picthis1
Aug 3, 2011 03:31 PM
Woofers
Feb 12, 2009 05:45 PM
dcmystery21
Oct 25, 2008 10:44 PM
Two400
Jan 22, 2008 04:10 PM
