ABS removal / Fuse
Old Mar 10, 2005 | 05:29 AM
seifer's Avatar
Default ABS removal / Fuse
I have a 98 Teg and Im getting very annoyed by the ABS system. I removed the fuse only so far. ABS is disabled, I get that nice light in the dash.
I was wondering, can it do something bad to disable it this way? Some friend told me it may not work again if I put back the fuse in like a year from now.
Old Mar 10, 2005 | 07:27 AM
98lsskunk's Avatar
Default Re: ABS removal / Fuse (fukushuu)
it will work if u want to put it back in but u need to get some rs brake lines if u dont want abs anymore
Old Mar 11, 2005 | 04:27 AM
seifer's Avatar
Default Re: ABS removal / Fuse (98lsskunk)
But wince I removed the ABS fuse, ABS doesnt function anymore? Why would I get some rs brake lines? Isn't it just the same since my ABS no longuer kicks in?
Old Mar 11, 2005 | 04:34 AM
b18psi's Avatar
To get rid of the pump weight. I am wanting to do the same thing. I have the RS Proportioning valve. Where do I find the brake lines?
Old Mar 11, 2005 | 04:39 AM
seifer's Avatar
Default Re: (b18psi)
You people with your tiny weight reductions... You may be right, it may do a diffrence but is it worth it for the trouble?
Ive seen a guy here posting something about he removed his front wypers to remove some weight! ...
Old Mar 11, 2005 | 06:38 AM
98lsskunk's Avatar
Default Re: (fukushuu)
well.. if you don't want ABS why dont you just get rid of it. it dose weigh quite abit and takes up room... sounds to me like you're lazy
Old Mar 11, 2005 | 07:20 AM
b18psi's Avatar
Default Re: (98lsskunk)
I second that.
Old Mar 23, 2005 | 07:59 PM
BoOsTiN Dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18psi &raquo;</TD></TR><TR><TD CLASS="quote">To get rid of the pump weight. I am wanting to do the same thing. I have the RS Proportioning valve. Where do I find the brake lines?</TD></TR></TABLE>
Search, its been covered already. JUST KIDDING! dont u hate it when people do that.
Ok, since you have the rs prop valve already what i would do is get the rs front brake lines going to the wheel and just use the gsr MC. Or you can purchase a flaring tool and pipe cutter from sears or something and cut and bend your own brake lines.
brian1037
Honda Civic (2001 - 2005)
14
Aug 23, 2011 07:49 PM
Whatislove
Aug 29, 2009 08:35 PM
rastropovitch
Oct 15, 2004 07:51 AM
vti444
Sep 6, 2004 12:44 PM
fw190bvi
Jan 7, 2004 11:20 AM
