putting a D15 head on D16 block?
Old Mar 9, 2005 | 10:39 PM
Tatakai's Avatar
Default putting a D15 head on D16 block?
I don't really know jack about D series.. I just got a D16 for $5, but it has a cracked valve. My civic has a perfectly fine D15, but i wouldn't mind an extra .1 liter under the hood.
By any chance, would it be possible to just use the D16 block, and use the D15 head? Will they bolt together? What will the compression be (about) - i want to eventually turbo the beast? What problems could I run into? Wiring?
D15B2 - from 1994 4dr Civic LX (where it's all going)
D16A6 - from (not sure) 88-91 Civic Hatch (unknown trim)
Any help appreciated. Of course, I did search HT for possible help.
Modified by Tatakai at 3:49 PM 3/10/2005
Old Mar 10, 2005 | 07:03 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: putting a D15 head on D16 block? (Tatakai)
Which D16? Which D15? Please be very VERY specific!
Old Mar 10, 2005 | 02:49 PM
Tatakai's Avatar
Default Re: putting a D15 head on D16 block? (tjbizzo)
Old Mar 11, 2005 | 06:03 PM
Tatakai's Avatar
bump
Old Mar 12, 2005 | 08:48 PM
Tatakai's Avatar
bump?
Old Mar 13, 2005 | 04:56 AM
Newt Dog's Avatar
Is the d15 head an 8 valve or 16 valve head? If it's a 16 valve head It will work.. If I was you I would fix the d16a6 head. It flow's better than the d15..
Old Mar 13, 2005 | 09:40 AM
Tatakai's Avatar
Default Re: putting a D15 head on D16 block? (Newt Dog)
i probably will, after i thought about it.. as far as i know it's just a cracked intake valve
chevmazda
Sep 16, 2007 09:11 AM
jsmithrn
Apr 26, 2007 12:14 PM
flashedDc5
Jan 2, 2006 08:08 PM
efcivicsi
Feb 20, 2003 09:17 PM
