Help diagnose smoking and ticking issue...
Old Mar 9, 2005 | 07:25 PM
jetpilot's Avatar
Default Help diagnose smoking and ticking issue...
Hey guys, I recently had new valve seals insalled for the second time on my LS head and it still keeps smoking when I stay on a low gear during a downhill or downshift abruptly (high vacuum) and then resume acelerating.
I also hear a metalic ticking noise coming from the exhaust side of the head.
Could this be a bent valve or a damaged valve guide or what??
TIA
Old Mar 10, 2005 | 01:29 AM
hondaguyef's Avatar
Default Re: Help diagnose smoking and ticking issue... (jetpilot)
Have you perormed a leakdown test? The metalic ticking is most likely detonation.
Phil
Old Mar 10, 2005 | 07:22 AM
sleeper96's Avatar
Default Re: Help diagnose smoking and ticking issue... (hondaguyef)
when your timing is set to high you get a metalic ticking noise.
Old Mar 10, 2005 | 07:51 AM
jetpilot's Avatar
I should have said, I only hear the noise when in idle and im pretty sure its not detonation cause my plugs are perfectly brown and my distributor is set at the middle position (I have to buy a timing light), also my tbelt is in perfect shape and alignment
Old Mar 10, 2005 | 03:38 PM
hondaguyef's Avatar
Default Re: (jetpilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetpilot &raquo;</TD></TR><TR><TD CLASS="quote">I should have said, I only hear the noise when in idle and im pretty sure its not detonation cause my plugs are perfectly brown and my distributor is set at the middle position (I have to buy a timing light), also my tbelt is in perfect shape and alignment</TD></TR></TABLE>
Adjust those valves then
Phil
Old Mar 11, 2005 | 10:41 AM
jetpilot's Avatar
that wont stop the smoking, what could the smoking be?
vdawg559
Jul 20, 2008 02:15 AM
gaby
May 21, 2008 07:18 AM
Clean.CL
Jan 29, 2005 09:44 AM
n00bs suck
15
Jul 29, 2004 06:47 AM
FMIDRC Racer
13
Oct 20, 2003 07:57 PM
